hi all,
We are looking into which files our users may want to share on our instance. Some could be a malware nightmare!
Are there any file extensions or uploads that aren’t supported on a hosted plan?
Thanks,
Emma
hi all,
Thanks,
Emma
Hi Emma,
No – you have full control over which file extensions you allow on your own instance. /admin/site_settings/category/files
There is a limit to how much storage space you have on a hosted plan though so bear that in mind.
Thanks, Hawk.
Is there an option to add on to the storage limit ?
Sure – by upgrading your plan. You can see the limits here.
(Bear in mind that Discourse isn’t designed as a file storage system so it is generally a good idea to educate your members to save large files elsewhere and link to them.)
