A bug has been reported where the system_messages.usage_tips.text_body_template does not respect the default language setting (zh_CN) when users are allowed to set their own language. louirobert initially thought it was a bug, but later found that it worked after a clean deployment from scratch. However, the exact cause is unknown, possibly due to a migration issue from a previous version (1.5.0.beta13b). techAPJ was unable to reproduce the issue locally and in a production environment, and has changed the category to support until repro steps are available.
I’m on version 1.6.0.beta1. My default site language is set to Chinese zh_CN but I allow user to use their own language setting. It works well for other parts but the text from system_messages.usage_tips.text_body_template, which is still in English, for users who are using the default zh_CN. I tried to set the site language to zh_CN and didn’t allow user’s own setting on that, then it was right. Thus I guess it’s a bug. Any ideas?
Update1:
I tried to set the site language to zh_CN and didn’t allow user’s own setting on that but it still doesn’t work. Sorry I was wrong just before.
Update2:
I can repeat the issue on my production deployment but not in my local development environment. They’re both v1.6.0.beta1.
I also created a fresh Discourse instance on DO droplet to try to repro this issue in production, but unable to repro it (with zh_CN locale and allow user locale setting enabled/disabled).
Changing the category to support until we have repro steps for this issue.
The newest update: I fixed that by dropping my database and deployed code and starting over.
Before, I had a deployment of v1.5.0.beta13b(which was upgraded to from an earlier 1.5.0 beta), and then I upgraded to v1.6.0.beta1. I’m not sure if it’s due to migration, or something else. Anyway, I have no easy way to figure out the reason. So I did a clean deployment from scratch and it seems working well.
