Tagging users (with interests/passions/skills etc)
The discussion revolves around the need for a way to tag users with interests, skills, or passions to facilitate better community engagement. Users like HAWK and alefattorini express interest in a feature that allows staff to identify and involve users in relevant discussions. While options like groups, custom badges, and personal topics with tags are proposed, concerns are raised about their limitations and usability. Mittineague demonstrates a workaround using SQL to query staff notes, and neil emphasizes the need for a clear separation between topic and user tags, suggesting that enhancing groups might be a more practical path. codinghorror notes that implementing user tags would require significant development effort, making it a low priority. The community agrees that while the feature is valuable, it’s not worth major work for an outlier use case. tanius proposes using personal topics as a proxy for user profiles, leveraging existing tagging systems in a creative way.
Continuing the discussion from Introducing the Staff Notes Plugin:
I’m really keen to find a way to tag users with interests/skills/passions so that I can pull people into relevant discussions.
I had hoped to use the staff notes plugin, but it’s not working out, so I’m wondering about the logistics of custom profile fields. How easy is it to pull that data?
Or perhaps a more appropriate question would be how would others approach this?
5 Me gusta
A couple other hacks I can think of (which may or may not meet your needs):
  • groups
  • custom badges
2 Me gusta
Thanks David – I’ve considered both. Groups is pretty limiting (I have to generalise to put people into one of x number of groups, rather than being to tag them with anything) although it is probably the most feasible option right now.
I’m generally against badges because they imply a level of expertise that not everyone is comfortable with. There are other connotations (not just categories of interest).
Ideally, I don’t want people to see the notes at all, but I’m aware that I might have to compromise on that. I currently use a spreadsheet that I manually search through, but I’d rather it was integrated somehow.
3 Me gusta
Well, that was fun.
What would have taken Rudy a heartbeat and a breath to put together …
On my localhost I had 4 Staff create a Staff Note starting with a made up “short code” on 4 different members.
~SHINING STAR~
This member has potential, lets keep an eye on them
Because the Profile Notes plugin created private messages I looked there - Nope
Staff Notes uses a different table
That table has no connection to the user the Staff Note was attached to except as the id as part of a string.
(some tricky stuff was needed, I’ll get better at Postgres yet)
This query
WITH psr AS (
 SELECT regexp_matches(plugin_store_rows.key, '[0-9]+') AS psr_key_value
   , plugin_store_rows.plugin_name AS psr_plugin_name
   , plugin_store_rows.value AS psr_value
 FROM plugin_store_rows
SELECT users.id
 , users.username
 , psr.psr_value
FROM users
JOIN psr
ON
 users.id = CAST (array_to_string(psr.psr_key_value, '') AS int)
WHERE
  psr.psr_plugin_name LIKE 'staff_notes'
AND
  psr.psr_value LIKE '%~SHINING STAR~%'
gave me
id 	username 	psr_value
11	TestUser1	[{"id":"40ce59592f6b5c81a692845cdbb0f9d4","user_id":11,"raw":"~SHINING STAR~\nThis member has potential, lets keep an eye on them","created_by":2,"created_at":"2016-04-04T21:00:20.055-04:00"}]
31	RegularGal1	[{"id":"327c342266b2efa7d1530aba02811056","user_id":31,"raw":"~SHINING STAR~\nThis member has potential, lets keep an eye on them","created_by":9,"created_at":"2016-04-04T21:09:15.413-04:00"}]
7	RegularGuy1	[{"id":"eeb581c3ff772ffdc476ea09c0dce156","user_id":7,"raw":"~SHINING STAR~\nThis member has potential, lets keep an eye on them","created_by":3,"created_at":"2016-04-04T21:03:09.804-04:00"}]
30	MemberGal1	[{"id":"73da2850045782a9fdb9d9ec7341d3a0","user_id":30,"raw":"~SHINING STAR~\nThis member has potential, lets keep an eye on them","created_by":34,"created_at":"2016-04-04T21:05:59.993-04:00"}]
5 Me gusta
Allan! You’re such a star. Thanks so much. I’ll give it a run tomorrow and see how I go.
Really appreciate it.
Edit: works like a charm.
1 me gusta
I’m really interested in this feature, my goals as community guy are pretty similar to @HAWK
Mentioning people into relevant discussions to them and where they can add a unique contribution is super important as external trigger, it keeps people still around the community and encourages to participate
4 Me gusta
great - I would love to see this too. I am involved in a number of community sites and it is something I think would be very useful - so users can self-identify with certain interests and then members and community managers can keep these specific groups updated with relevant content
I’m not yet sure whether I would prefer them to pick from a list, or to enter their own tags, but in either case it would be a useful feature that is separate from the ‘Groups’ function, and the Badges
Happy to help scope this out better if needed
1 me gusta
With tags into the core, can you take this into account? It would be awesome see that on Discourse.
Did this ever go anywhere? I also found this topic
https://meta.discourse.org/t/add-user-fields-support-for-field-type-tag/42721/5
which also seems to have gone only half-way to a permanent solution.
What I would find useful is a multiple choice dropdown field like in the composer
It would then make sense to be able to search for users with a specific tag.
Currently Customize > User Fields only allows single choice dropdowns (as does the Custom Wizard Plugin) and I’m not sure if searching for those fields returns anything.
1 me gusta
Yeah, I can still see huge value in this. Being able to quickly tag a user rather than adding them to multiple groups would be great. I don’t think this is trivial though. @neil may be able to add more to the conversation. He did a lot of work on our current tagging.
3 Me gusta
This is a cool idea! If at present users < > groups are tightly linked, and topics < > tags are tightly linked — such that establishing a connection between users < > tags would be a lot of work — perhaps a simple(ish) solution could be:
  • New site setting enable group quick add (and perhaps group default visibility)
  • When enabled, rather than just allowing selection of existing groups on a user edit page, you could also enter a group name that doesn’t already exist and it’d create it as a closed group with some simplified default settings
Basically a way to enable just-in-time group creation that’s functionally as easy as adding tags. Not sure if there are other ways tags might still be a better way to go, just one idea!
2 Me gusta
Creo que necesitamos una separación clara entre las etiquetas de temas y las etiquetas de usuarios. No queremos etiquetar a un usuario con Customization > Theme component o pr-welcome, por ejemplo, porque carece de sentido. La página /tags también debe tener coherencia, por lo que mezclar allí etiquetas de temas y de usuarios sería incorrecto. La mayor parte del trabajo para añadir etiquetas de usuarios implicaría nuevo desarrollo (interfaz de usuario, modelos de datos).
Creo que la mayoría de las personas querrán usar las etiquetas de usuarios de la misma manera en que usamos los grupos (menciones, categorías restringidas, etc.), así que tal vez @bts tiene razón al decir que esto es realmente una solicitud para mejorar los grupos.
9 Me gusta
Totally agree on the hard separation and the groups extension would work in some cases but I’m not totally convinced that the group route is the right one. In my use case from the OP there is sometimes just 1 person with a tag and often just 2 people. Hundreds of 1 and 2 people groups would be pretty cumbersome.
How much work would be involved with going down the tagging road?
3 Me gusta
A ton. It’d be major feature work. I’m not inclined to do it at this time. Improving groups benefits everyone much more.
5 Me gusta
Yeah, def not worth doing a tonne of work for this outlier of a use-case.
1 me gusta
Aquí hay otro más para esa lista: bastante obvio, pero no se me ocurrió. A alguien más de nuestro foro sí.
  • etiquetas en temas “personales”
Los temas personales serían solo una convención: un tema por usuario, en una categoría determinada. De esta manera, estos temas actúan como representantes de los usuarios. La categoría para ellos puede ser pública (para que los usuarios publiquen sus propios temas personales) o no (para que los miembros del personal almacenen internamente información sobre solicitantes de empleo, por ejemplo). Las etiquetas disponibles pueden estar vinculadas a esa categoría (por ejemplo, usando un grupo de etiquetas de “habilidades”) para que no puedan usarse en temas “normales”.
Siempre me interesa esto.
Intenté explicar lo que quiero decir (Member tags - #3 by alefattorini), ¿no es interesante desde la perspectiva de la comunidad?
