Benutzer-Tags zuweisen
Can tags be added to users?
No. Only groups.
What problem are you trying to solve?
We’re helping a charity. They asked for a way to determine the skills and interests of the volunteers. I started using CustomUserField but ran into a hard coded limit. I thought of using tags.
I think groups will cut it.
Thanks Jay :slight_smile:
What about custom badges? You can easily list volunteers with specific ones. Example:
https://meta.discourse.org/badges/3/regular
Can a user set their own custom badges?
I don’t think so, but they can freely join and leave groups to which you can assign automatic badges:
https://meta.discourse.org/t/badge-sql-can-no-longer-be-edited-by-default/47894/30?u=omarfilip
Ah. That helps make sense of your questions! I couldn’t figure why you needed so many custom fields. You could get a plugin to create tags on a custom field, but groups seem like a workable solution.
See also:
