Tags are not working due to multilingual plugin
Tags are not working. I get Oops! That page doesn’t exist or is private when try to open any of them.
All tags have a root /tags/ and the root was changed as I found here. So when I change /tags/any-tag to /tag/any-tag - it works.
I’m on 2.7.0.beta1 ( 4f72830eb0 )
How this problem can be solved?
Can you reproduce this issue on meta?
No, all links are working here, e.x. https://meta.discourse.org/tag/official/. All links from tags have a correct root.
I updated my test server to 2.7.0.beta1 ( d8b015e3be ) and still get this error.
This happens everywhere - when I click the tag in any post or do it on the Tags page.
I think, that this FAQ should be changed because Tags core url was changed.
Does anybody have an idea of how to fix my problem - change /tags/ to /tag/ in all urls?
The problem was found in the plugin.
To make troubleshooting easier in the future, I’d try safe mode to eliminate the source of the issue.
