マウスが通過するとテキストの色が変わる
I do not know the name but would like to change the colors, but I did not find how to do that.
I want the same as Gmail
I am not following, please provide a screenshot of Discourse, not some random other service with no relationship to Discourse.
alterar%20cores
can not find the code to change
You can’t change that AFAIK, it’s set by your computer’s operating system and the browser.
It’s the difference between browser-native tooltips (implemented with the title attribute) and custom tooltips, implemented in some other way.
It’s not elementary to change on a site-wide basis — you can’t just add some custom CSS to change the appearance of titles, as they’re not styled by CSS. There might be a hacky way to replace them using some custom JavaScript and MutationObservers, though performance may be affected.
「いいね!」 3
Thanks for the answer
Here’s a proof of concept:
Repo | Live demo
Strictly for reference only and not production ready… unless you reeeally love Comic Sans MS, in which case, use at will. :grin:
This is actually even hackier than what I originally suggested — it uses setInterval every 100ms rather than a MutationObserver.
「いいね!」 3
