Text missing in Discourse Docs top menu button
I have the Discourse Docs docs add to top menu option enabled, and I recently noticed that the button had disappeared. It’s actually still there, but has no text so it is invisible until you mouse over it:
I had previously customised the js.docs.title text to say Knowledge Base, but I’ve reverted that change and it hasn’t fixed the problem:
The text is definitely missing from the HTML (ie. I don’t think it’s a CSS problem):
I’m running Discourse version 925da123d9 (latest beta) with discourse-docs version 834d22d868e.
I’ve tested with the Light theme and just this component enabled and the problem was still there.
I see the button is working on Meta, so maybe it’s just a slight incompatibility with the beta branch?
I think this was reported recently, and there’s a fix in place:
If you can update to Latest from your /admin/upgrade page that should fix the issue. :+1:
Ah, thank you very much, that’ll be it. Sorry for not finding the previous thread :man_facepalming:
That’s okay. I like bugs that have already been fixed. :slight_smile:
This topic was automatically closed after 5 hours. New replies are no longer allowed.
