최근 이곳의 지침을 따라 영구 삭제 기능을 활성화했습니다: Introducing permanently delete post functionality
이제 “영구 삭제” 옵션을 볼 수 있습니다.
그러나 토픽을 삭제하려고 하면 다음과 같은 알림이 표시됩니다:
/logs를 확인하면 다음과 같은 내용이 나옵니다:
net-http-0.2.2/lib/net/http/response.rb:142:in `error!'
net-http-0.2.2/lib/net/http/response.rb:151:in `value'
net-http-0.2.2/lib/net/http.rb:1039:in `connect'
net-http-0.2.2/lib/net/http.rb:995:in `do_start'
net-http-0.2.2/lib/net/http.rb:984:in `start'
net-http-0.2.2/lib/net/http.rb:1570:in `request'
rack-mini-profiler-3.0.0/lib/patches/net_patches.rb:19:in `block in request_with_mini_profiler'
rack-mini-profiler-3.0.0/lib/mini_profiler/profiling_methods.rb:46:in `step'
rack-mini-profiler-3.0.0/lib/patches/net_patches.rb:18:in `request_with_mini_profiler'
net-http-0.2.2/lib/net/http.rb:1480:in `request_get'
fastimage-2.2.6/lib/fastimage.rb:296:in `fetch_using_http_from_parsed_uri'
fastimage-2.2.6/lib/fastimage.rb:278:in `fetch_using_http'
fastimage-2.2.6/lib/fastimage.rb:244:in `initialize'
fastimage-2.2.6/lib/fastimage.rb:140:in `new'
fastimage-2.2.6/lib/fastimage.rb:140:in `size'
/var/www/discourse/lib/cooked_processor_mixin.rb:186:in `get_size'
/var/www/discourse/lib/cooked_post_processor.rb:158:in `convert_to_link!'
/var/www/discourse/lib/cooked_post_processor.rb:369:in `block in post_process_images'
nokogiri-1.13.8-x86_64-linux/lib/nokogiri/xml/node_set.rb:234:in `block in each'
nokogiri-1.13.8-x86_64-linux/lib/nokogiri/xml/node_set.rb:233:in `upto'
nokogiri-1.13.8-x86_64-linux/lib/nokogiri/xml/node_set.rb:233:in `each'
/var/www/discourse/lib/cooked_post_processor.rb:367:in `post_process_images'
/var/www/discourse/lib/cooked_post_processor.rb:44:in `block in post_process'
/var/www/discourse/lib/distributed_mutex.rb:57:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:53:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:38:in `synchronize'
/var/www/discourse/lib/cooked_post_processor.rb:40:in `post_process'
/var/www/discourse/app/jobs/regular/process_post.rb:26:in `block in execute'
/var/www/discourse/app/jobs/regular/process_post.rb:10:in `execute'
/var/www/discourse/app/jobs/base.rb:237:in `block (2 levels) in perform'
rails_multisite-4.0.1/lib/rails_multisite/connection_management.rb:80:in `with_connection'
/var/www/discourse/app/jobs/base.rb:226:in `block in perform'
/var/www/discourse/app/jobs/base.rb:222:in `each'
/var/www/discourse/app/jobs/base.rb:222:in `perform'
sidekiq-6.5.6/lib/sidekiq/processor.rb:202:in `execute_job'
sidekiq-6.5.6/lib/sidekiq/processor.rb:170:in `block (2 levels) in process'
sidekiq-6.5.6/lib/sidekiq/middleware/chain.rb:177:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:138:in `call'
sidekiq-6.5.6/lib/sidekiq/middleware/chain.rb:179:in `block in invoke'
sidekiq-6.5.6/lib/sidekiq/middleware/chain.rb:182:in `invoke'
sidekiq-6.5.6/lib/sidekiq/processor.rb:169:in `block in process'
sidekiq-6.5.6/lib/sidekiq/processor.rb:136:in `block (6 levels) in dispatch'
sidekiq-6.5.6/lib/sidekiq/job_retry.rb:113:in `local'
sidekiq-6.5.6/lib/sidekiq/processor.rb:135:in `block (5 levels) in dispatch'
sidekiq-6.5.6/lib/sidekiq.rb:44:in `block in <module:Sidekiq>'
sidekiq-6.5.6/lib/sidekiq/processor.rb:131:in `block (4 levels) in dispatch'
sidekiq-6.5.6/lib/sidekiq/processor.rb:263:in `stats'
sidekiq-6.5.6/lib/sidekiq/processor.rb:126:in `block (3 levels) in dispatch'
sidekiq-6.5.6/lib/sidekiq/job_logger.rb:13:in `call'
sidekiq-6.5.6/lib/sidekiq/processor.rb:125:in `block (2 levels) in dispatch'
sidekiq-6.5.6/lib/sidekiq/job_retry.rb:80:in `global'
sidekiq-6.5.6/lib/sidekiq/processor.rb:124:in `block in dispatch'
sidekiq-6.5.6/lib/sidekiq/job_logger.rb:39:in `prepare'
sidekiq-6.5.6/lib/sidekiq/processor.rb:123:in `dispatch'
sidekiq-6.5.6/lib/sidekiq/processor.rb:168:in `process'
sidekiq-6.5.6/lib/sidekiq/processor.rb:78:in `process_one'
sidekiq-6.5.6/lib/sidekiq/processor.rb:68:in `run'
sidekiq-6.5.6/lib/sidekiq/component.rb:8:in `watchdog'
sidekiq-6.5.6/lib/sidekiq/component.rb:17:in `block in safe_thread'
이 인스턴스에서 몇 가지 기능에서 502 오류가 발생하고 있으며, 이로 인해 라이트박스(lightboxing)와 같은 기능이 작동하지 않고 있습니다. 502 오류는 아마도 VPN, 자체 서명된 인증서 또는 프록시 때문일 것입니다.
그러나 영구 삭제 기능이 이러한 문제의 영향을 받는 이유가 무엇인지 이해가 되지 않습니다. 토픽 게시 등(완전히 정상적으로 작동하는) 것과 유사하게 데이터베이스에 직접 쓰는 과정일 것이라고 생각했기 때문입니다.
비슷한 경험을 하신 분이 계신가요?
