"Time" invoerpictogram is zwart op donker thema
See:
It’s expected to be a light color, probably var(--primary). :slight_smile:
I notice it uses a time input which I wasn’t aware it existed, so I don’t know if it can be changed, especially if the design varies depending on the device/browser used :thinking:
I use Desktop Chrome 108.0.5359.125 on Windows 11.
I don’t see the second time indicator:
What device/OS/browser combination is this?
I edited my topic to add this info: Desktop Chrome 108.0.5359.125 on Windows 11.
I can repro on Chrome. It adds a clock to input type="time".
https://stackoverflow.com/questions/63002686/how-do-i-change-the-color-of-the-small-clock-icon-that-comes-with-the-html-input#comment119665982_64184578 for a Webkit-based browsers solution.
If you don’t want to see the clock you can always
input[type="time"]::-webkit-calendar-picker-indicator {
    background: none;
