ganncamp
(G Ann Campbell)
1
If I’m looking at a list of topics (New, Latest &etc) I can see the number of Views per topic.
It would be nice to have access to that stat from within the topic itself, rather than having to back out, and find the topic in a list.
It’s reasonable to me that this wouldn’t necessarily be visible by default (i.e. in the topic header) but probably from the wrench menu.
Stephen
(Stephen)
Topic views are visible below the OP assuming it has responses. On mobile the bar below op needs to be expanded to see them:
Desktop:
Normal:
Expanded:
renato
(Renato Atilio)
3
Personally I think this should be visible by default somehow, but there is a workaround posted recently that I’m successfully using in my community:
Moin
4
