Onderwerpen gedempt door "mute all by default" verschijnen als nieuw... maar zijn niet zichtbaar
Heather_Dudley reports a bug where muted categories (under “mute all by default” settings) still appear as “new” in notifications despite being muted, causing confusion and inability to dismiss unread indicators. She provides screenshots and a GIF showing muted threads appearing in the hamburger menu and unread lists, even though they’re invisible when clicked. sam acknowledges the issue and asks kris.kotlarek to extend an existing fix to cover “mute all by default” scenarios. kris.kotlarek confirms a fix has been implemented (PR #11441) to make unread counters behave predictably and asks Heather to report if the issue recurs. The core problem: muted content shouldn’t appear as new or unread, but currently does, especially in large category structures like “Regions.”
Our site is set up as mute all categories by default. Unfortunately, some things are still “getting through” in obnoxious ways.
I have the conversation forums all unmuted, but the regions (about 700 or so categories) are still showing in some way in the new notifications. HEre’s the hambuger menu"
Here’s the regions category, all the muted categories are listed as subcategories of this one, which I have unmuted:
There are four new threads listed, and the new/updated topics are also in the muted forums. They shouldn’t be appearing for me at all, because I have them muted.
Here’s the actual live experience trying to view those new/unread. Note that I can’t dismiss them as new or unread because they are muted and don’t appear.
hidden new threads
Here’s the still of the final frame. ALL of the posts listed here, with the exception of the ones in the Regions and USA :: Georgia :: Macon forum ARE muted for me. The other ones are threads I’ve interacted with in some way (usually unpinning since they like to globally pin things) but are still appearing in muted forums.
I have NO clue what the New posts are, because nothing I can do will make them appear for me.
It will occasionally clear them out and they won’t appear as new after a while, but this happens a LOT.
We can get this sorted, we have a similar fix already in place for standard muted topics.
@kris.kotlarek can you add to your list to also allow for mute all by default?
Hey @Heather_Dudley,
I made a fix. From now on the counter should behave more predictable.
I will close that ticket for now but please let me know if you experience that issue again :slight_smile:
