Tor browser verpest afbeeldingen door lokale optimalisatie
The Tor browser is causing issues with image uploads on Discourse, specifically corrupting JPG files. RGJ found a temporary workaround by setting composer media optimization image bytes optimization threshold to a high value. Falco investigated and discovered that the Tor browser is blocking a specific call and silently corrupting return values. Disabling privacy.resistFingerprinting.autoDeclineNoUserInputCanvasPrompts in about:config resolves the issue by prompting users for permission. Decorbuz inquired if this fix also applies to similar issues with favicon uploads, but this was not confirmed.
Uploading an image using the Windows Tor browser wrecks JPG uploads.
Setting composer media optimization image bytes optimization threshold to something ridiculously high circumvents the problem. This is very likely an issue with the Tor browser but so far it seems only to be happening in Discourse so I thought I’d post it here anyway, even if it’s only to share the workaround trick.
On my test the Tor browser blocked this call here:
with
Blocked https://try.discourse.org/ from extracting canvas data because no user input was detected.
which is obviously a lie, since the File Picker is user input.
That was detect by our failsafe mechanism:
Resize failed: Image corrupted during resize. Falling back to the original for encode
Which prompts Discourse to only re-encode the file, which appears to be successful, but then fails with a 422 when finishing the multi-part upload…
Tor Browser should block the canvas creation API instead of silently corrupting return values :thinking:
Anyway, looks like users can disable the silently failure of canvas operations by toggling privacy.resistFingerprinting.autoDeclineNoUserInputCanvasPrompts on about:config which will allow users to see this prompt:
I just tested and that fixes the upload.
Impressive. Thank you @falco!!!
In my experience, the same issue also occurs with some favicons (presumably uploaded as JPG files). Does toggling privacy.resistFingerprinting.autoDeclineNoUserInputCanvasPrompts also fix that issue?
