Página de actualizaciones completamente en blanco
My upgrades page is completely blank.
I did ./launcher rebuild app and managed to upgrade to v2.6.0beta4, but even afterward, the upgrades page is blank. The <body> tag for the page is:
<body class="highlighter-context">
</body>
Any suggestions?
Can you share a link to your site?
1 me gusta
It’s a closed forum. Happy to share but I figure that makes a difference, yeah?
I recommend you remove all third party plugins and rebuild. Also try safe mode see:
1 me gusta
Thanks. I got some time to try these. Various options in safe mode didn’t help. Disabling all third-party plugins and including only docker_manager also didn’t change anything. Still a blank white screen.
I saw a post with the same issue from earlier this year, but the OP stopped responding, so no obvious cause or resolution.
I recommend posting a sanitized version of your app.yml … it will help us figure out what is wrong.
Okay, here you go:
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
#  - "templates/web.ssl.template.yml"
#  - "templates/web.letsencrypt.ssl.template.yml"
  - "templates/web.socketed.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
#  - "80:80"   # http
#  - "443:443" # https
params:
  db_shared_buffers: "128MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 2
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: <REMOVED FOR PUBLIC POSTING>
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: <REMOVED FOR PUBLIC POSTING>
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: <REMOVED FOR PUBLIC POSTING>
  DISCOURSE_SMTP_PASSWORD: <REMOVED FOR PUBLIC POSTING>
  DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: <REMOVED FOR PUBLIC POSTING>
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  # S3 Setup
  DISCOURSE_CDN_URL: <REMOVED FOR PUBLIC POSTING>
  DISCOURSE_USE_S3: true
  DISCOURSE_S3_REGION: "us-west-002"
  DISCOURSE_S3_ENDPOINT: https://s3.us-west-002.backblazeb2.com
  DISCOURSE_S3_ACCESS_KEY_ID: <REMOVED FOR PUBLIC POSTING>
  DISCOURSE_S3_SECRET_ACCESS_KEY: <REMOVED FOR PUBLIC POSTING>
  DISCOURSE_S3_CDN_URL: <REMOVED FOR PUBLIC POSTING>
  DISCOURSE_S3_BUCKET: <REMOVED FOR PUBLIC POSTING>
  DISCOURSE_S3_BACKUP_BUCKET: <REMOVED FOR PUBLIC POSTING>
  DISCOURSE_BACKUP_LOCATION: s3
  DISCOURSE_S3_INSTALL_CORS_RULE: false
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-user-notes
          - git clone https://github.com/discourse/discourse-assign
          - git clone https://github.com/discourse/discourse-policy
          - git clone https://github.com/discourse/discourse-tooltips
          - git clone https://github.com/discourse/discourse-saved-searches
          - git clone https://github.com/discourse/discourse-knowledge-explorer
          - git clone https://github.com/discourse/discourse-voting
          - git clone https://github.com/discourse/discourse-translator
          - git clone https://github.com/angusmcleod/discourse-elections
          - git clone https://github.com/discourse/discourse-styleguide
          - git clone https://github.com/Ahmedgagan/discourse-custom-trust-level
          - git clone https://github.com/paviliondev/discourse-quick-messages
          - git clone https://github.com/paviliondev/discourse-locations
          - git clone https://github.com/discourse/discourse-calendar
  # Object storage
  after_assets_precompile:
    - exec:
        cd: $home
        cmd:
          - su discourse -c 'bundle exec rake s3:upload_assets'
run:
ok… step one I recommend here is rebuilding this thing without any third party plugins. Only keep ones that are /discourse/discourse
Then if that works you can bisect to find out which plugin is causing the trouble.
Well, docker_manage plugin is not a discourse/discourse path, but with it disabled, ...admin/upgrade page doesn’t exist.
Enabling only the docker_manage plugin results in the same blank upgrades page.
1 me gusta
GitHub - discourse/docker_manager: Plugin for use with discourse docker image ?
Sorry, you’re right, I must have been hallucinating. Scratch that, it is in the discourse/ path.
But anyway, still a blank white screen.
With the availability of 2.6.0.beta5 (I’m on 2.6.0.beta4), I’m still running into a blank upgrades page. I’d be grateful for any further advice, since I’ve tried disabling plugins to no avail.
Have a look at chrome dev tools, are there any errors in the console when the page is white? My guess is that this is something to do with your CSP.
1 me gusta
Thank you, you’re right—it’s refusing to load a script coming through my CDN. With url’s sanitized:
upgrade:1 Refused to load the script 'https://cdn-to-discourse.b-cdn.net/assets/docker-manager-app-32418f2f7cd50e6f4a0b8d13badc4e59f6a1ad74e7bed270f3a051478fed773d.js' because it violates the following Content Security Policy directive: "script-src https://forum.example.com/logs/ https://forum.example.com/sidekiq/ https://forum.example.com/mini-profiler-resources/ https://cdn-to-s3.b-cdn.net/assets/ https://cdn-to-s3.b-cdn.net/brotli_asset/ https://forum.example.com/extra-locales/ https://cdn-to-discourse.b-cdn.net/highlight-js/ https://cdn-to-discourse.b-cdn.net/javascripts/ https://cdn-to-discourse.b-cdn.net/plugins/ https://cdn-to-discourse.b-cdn.net/theme-javascripts/ https://cdn-to-discourse.b-cdn.net/svg-sprite/ https://matomo.example.com". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
The Security settings page says “The current host and CDN are included by default.” Should I manually add the CDN to the whitelist anyway?
I see that an identical issue was brought up here, without a final answer about why the default whitelisting wasn’t working.
1 me gusta
Hello,
I think you should add this url to admin CSP setting (content security policy script src):
Screen Shot 2020-11-02 at 7.30.47 PM
And after check again the chrome dev tools errors.
Yes that works. I’m curious why the default whitelisting is not doing this automatically, though.
I am curious as well, how is your CDN configured? We may be missing some magic from docker-manager plugin.
cc @pmusaraj
4 Me gusta
Yes, indeed, we were. The docker_manager plugin was loading two JS files in a template using javascript_include_tag, which isn’t aware of DISCOURSE_S3_CDN_URL so it was defaulting to DISCOURSE_CDN_URL and tripping up the CSP.
Should be fixed now via FIX: blank upgrade page when using S3 CDN and CSP · discourse/docker_manager@3d37fd6 · GitHub
@paulrudy if you update the docker_manager plugin, you should no longer need to manually add https://cdn-to-discourse.b-cdn.net/assets/ to your CSP.
6 Me gusta
That did the trick! Thanks @sam and @pmusaraj
4 Me gusta
