fhe
(Florian)
17.Май.2018 08:11:55
1
I’ve just tried to update from Discourse 2.0.0 beta 9 to beta 10 and I’m now faced with a blank page on /admin/upgrade after updating docker manager.
I’ve tried to restart the app via ./launcher which didn’t trigger the other previously listed available updates to reappear. Previous updates worked flawlessly.
Any ideas on how to proceed from here?
4 лайка
tgxworld
(Alan Tan)
17.Май.2018 08:33:23
Any errors in the console?
4 лайка
fhe
(Florian)
17.Май.2018 08:35:45
3
I’ve only seen the DONE in the end and closed it. Is this stored somewhere to inspect in again?
2 лайка
sam
(Sam Saffron)
17.Май.2018 08:37:03
4
I recall we had to run something to rebuild the bundle, did @featheredtoast do that with his update ?
4 лайка
Just chiming in to say that I’ve just run into this as well after upgrading the Docker Manager.
edit And a note from my friend who maintains my forum.
“The first rebuild failed halfway through, leaving the container in a moderately bad state where services weren’t starting, but rerunning the rebuild worked fine.”
1 лайк
fhe
(Florian)
17.Май.2018 11:35:55
6
I’ve also went the ./launcher rebuild app route, needed to revert some changes I’ve made to discourse-setup (adjusted some ports to the ones I’m using here), was faced with a Driver aufs failed to remove root filesystem error message from docker, rebooted the server did ./launcher rebuild app again and now…
… everything is working fine again.
fefrei
(Felix Freiberger)
17.Май.2018 11:40:47
7
I’m having the same issue. It’s an internal server error:
The internal error is:
NoMethodError (undefined method `visible_plugins' for Discourse:Module)
/var/www/discourse/plugins/docker_manager/app/controllers/docker_manager/admin_controller.rb:50:in `repos'
Here’s a backtrace:
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/basic_implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:186:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:131:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/rescue.rb:20:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications/instrumenter.rb:21:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/notifications.rb:166:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal/params_wrapper.rb:252:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-5.1.4/lib/active_record/railties/controller_runtime.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/abstract_controller/base.rb:124:in `process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionview-5.1.4/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:189:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_controller/metal.rb:253:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:31:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:50:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/journey/router.rb:33:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/route_set.rb:834:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/engine.rb:522:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/railtie.rb:185:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:17:in `block in <class:Constraints>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/routing/mapper.rb:46:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-protection-2.0.1/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/conditional_get.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:200:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/cookies.rb:613:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:26:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activesupport-5.1.4/lib/active_support/callbacks.rb:97:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/callbacks.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/debug_exceptions.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/logster-1.2.9/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:36:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/railties-5.1.4/lib/rails/rack/logger.rb:26:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/remote_ip.rb:79:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-5.1.4/lib/action_dispatch/middleware/request_id.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rails_multisite-2.0.4/lib/rails_multisite/middleware.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/message_bus-2.1.4/lib/message_bus/rack/middleware.rb:63:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:186:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rack-2.0.4/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.4.0/bin/unicorn:23:in `<main>'
6 лайков
I’m having the very same issue.
zogstrip
(Régis HANOL)
17.Май.2018 15:50:20
9
@featheredtoast looks like it’s related to your change ?
1 лайк
bts
(Brendan Schlagel)
17.Май.2018 15:55:16
11
Hmm I made a topic reporting this yesterday and can’t find it now, seems it may have been deleted…
Working for me after rebuild though. (I think I had to run ./launcher rebuild app twice for some kind of database cleanup task.)
1 лайк
Sorry about that – anyone affected by this will need to rebuild, for anyone holding off, I was depending on a newer version of discourse for the manager itself, 1 moment…
5 лайков
EddieC
17.Май.2018 15:58:39
13
I can confirm that ./launcher rebuild app will return things to normal again.
1 лайк
EddieC
17.Май.2018 16:02:59
14
What’s weird is that all the Discourse native plugins are gone suddenly:
You’re probably talking about lazyYT and discourse poll!
those are now a part of core and that is why are not displayed as a plugin.
5 лайков
That’s expected - “plugins” that are shipped with discourse aren’t really plugins (every Discourse instance has them!) so they have been removed from that page.
7 лайков
This topic was automatically closed after 32 hours. New replies are no longer allowed.
