I have a discourse website ayushlive.com
I saw a message on the admin dashboard which asks to upgrade the website but the upgrade link is not there and the upgrade page does not exist.
Please suggest what to do. I do not see any errors on the website.
You can do manual update.
Thanks. Manual update works fine. But I wanted to know why the page is not there. I need to do it myself or give access to the server to someone in this case.
I have more discourse sites, all installed in the same way but they show upgrade page and option. This one does not.
I have never seen a discourse site not on a subdomain. How/why did you install it on https://ayushlive.com instead of using a subdomain like https://forum.ayushlive.com? Do you have any other problems with your site?
All my sites are on main domain only. No other problems.
How - I dont see any difference in using sub domain or main domain.
Why - I am using this as main website. It has every feature I need for now.
And all your sites with no other problems are discourse forums? Or is this your only discourse forum?
I have multiple discourse sites. all on main domains. no issues.
cool - that’s good to know. are you seeing this problem with the admin upgrade page not existing on any of your other sites?
No. Only on this one.
ok I guess I’m barking up the wrong tree then.
It’s good to know there are no issues with sites on the main domain.
I honestly don’t know what the issue is you are having. Either you are not logged in as admin when you go to /admin/upgrade or you have an oddball installation issue, perhaps with a plugin.
I am admin as I can upgrade the themes and components.
About plugin - may be. Lets call it a day unless someone else also faced it and they can come n share their experience.
Thanks a lot.
Are you sure this is a default docker setup and not a custom one?
I always use the guide. I have never used custom docker.
Is there a way to check?
Do you have the discourse_docker plugin installed?
No. I only have discourse-adplugin installed.
The Discourse-docker plugin is what provides /admin/upgrade
