Tracking referrals? Encouraging users to invite others?
The discussion revolves around tracking referrals and encouraging users to invite others to grow a site. shaundefense wants to run a contest where the user who invites the most active users in 30 days wins, but needs help tracking invites and user activity sitewide.
fefrei suggests using the Data Explorer plugin to run custom SQL queries against the Discourse database. SidV provides an example query to track invites and user activity, and also shares a queries’s directory with additional queries.
SidV later adds a tracking-referrals.sql query to the list. However, Henry_Cooper encounters a syntax error when trying to run this query. SidV and Henry_Cooper resolve the issue, as the error was due to copying and pasting both queries instead of just one.
I’m looking for ways to grow my site. We are close to 1000 members but we just hit a slump in growth.
We plan on doing a contest of some type but we want to make sure the contest encourages further growth. We thought about doing a contest: Whoever invites the most active users in 30 days wins.
This could be effective but the problem is I don’t see any admin overview of signups via invite or sitewide user activity, so it would be difficult to track.
Does anyone know of a way we can track invites and user activity sitewide?
This is something for the Data Explorer plugin, it allows you to run custom SQL queries against the Discourse database.
If you’re somewhat versed in SQL, using Data Explorer is pretty easy since it has included help to show you the database scheme; otherwise, I’m sure you’ll get some help here if you describe what you want, exactly :slight_smile:
As @fefrei said, you can use Data Explorer with a query like this:
-- [params]
-- int :limit
select user_id,
    invited_by_id
from invites
where created_at > CURRENT_TIMESTAMP - INTERVAL '30 days'
and user_id > 1
limit :limit
And modify that query with more complex query if you want.
See this queries’s directory that you can use
Good luck !
Ps, updated: I added tracking-referrals.sql to the list :wink:
Thanks for the help!
I tried running this and got a syntax error “at or around line 25”
Henry, on that link there are two queries. Which version are you trying ?
I tested the both now, and works fine. :thinking:
Oops. Didn’t notice there was two. I ended up copy pasting both thinking it was one.
Problem solved :slight_smile:
