Translation to Azerbaijan language
In a discussion titled ā€˜Translation to Azerbaijan language’ within the Translations category, user eminov requests assistance in translating their Discourse site from English to Azerbaijani. The user initially attempted to adapt Turkish locale files but found the changes did not reflect on the site eminov. User Nam_Nguyen suggested several approaches: contributing via Transifex, manually editing text content via the Admin panel, or developing a language plugin. When eminov clarified they needed to add the language to Transifex or modify existing Turkish files, user simon proposed customizing Turkish strings through the Admin > Customize > Text Content section. However, eminov noted this only covers a fraction of the needed translation. Finally, user Falco directed eminov to follow the official guide on how to add a new language, emphasizing the process involves submitting a Pull Request for the changes to be merged into Discourse, which subsequently makes the language available on Transifex.
Hi. I need translation my site to Azerbaijan language. But I can not translate language on the transfixes.com
I changed some files with turkey language to azerbaijan (same like language) in files /config/locales/server.tr_TR.yml
but this changed words dont view in my site. Why?
How translated my site to my native language?
1 curtida
I need to translate discourse cms from english into azerbaijan language. But I could not find Azerbaijan language in your system. That why I can not translate this project to my language. What should I do? Anybody help me.
I think there are some ways to translate Discourse, :slight_smile:
###1: Translate via Transifex, you can see these topics.
###2: Translate through Text Content
###3: Create Translate language plugin
I found an example on Github, and I’m not sure it can work with latest discourse
Here is a tip how to add a new language
6 curtidas
This post doesn’t help me. How add new language on transifex? I don’t have add Azerbaijan language as new language. Or how change for example Turkish language to Azerbaijani? Which I saving tr_TR file on my site this files will be translated on my language?
You could customize the Turkish language strings for your forum on the admin/customize/site_texts page.
In this area 4 section to translate. I need full translate my site. :fearful:
You need to follow this, then send a PR with the changes that we will merge and then the new language will be available on transifex.
4 curtidas
