如何添加一种新语言
Contribute translations
The first step is to do some translating in our Crowdin workspace. Create an account and start translating in one or more languages. See Contributing translations to Discourse for more information about that.
Add language to Discourse
:warning: These instructions are currently out of date!
You have two options when you think that the translation is ready to be included in Discourse:
  1. Post in this topic and ask for your language to be included in Discourse. There might be a helpful community member who will add it for you.
  2. You add it yourself. :muscle:
    If you do, please read on…
Requirements
You will need a development environment (Linux, macOS or Windows) and a working Transifex client. Moreover, you need to fork and clone the discourse and translations-manager git repositories.
Find the language codes
I’ll use Welsh (cy_GB) as an example to show you the next steps. First, take not of the language code used by Transifex. It will look like this:
:bulb: In some cases, Transifex will use a language code that isn’t supported in Rails.
In order to find out, take a look at config/locales/plurals.rb in the discourse repository. For Welsh you will find a line like this:
cy: { i18n: { plural: { keys: [:one, :two, :many, :other], rule: lambda { |n| n == 1 ? :one : n == 2 ? :two : n == 8 || n == 11 ? :many : :other } } } },
So, the language code in Transifex is cy_GB and cy in Discourse.
Add language to translations-manager
Edit lib/translations_manager/locales.rb in the translations-manager repository and add the language code used by Discourse to the SUPPORTED_LOCALES array.
Add an entry to the LANGUAGE_MAP hash if the language code in Transifex differs from the one used by Discourse.
The diff for Welsh would look like this:
@@ -5,6 +5,7 @@ module TranslationsManager
     'bs_BA',
     'ca',
     'cs',
+    'cy',
     'da',
     'de',
     'el',
@@ -44,6 +45,7 @@ module TranslationsManager
   # 'language code in transifex' => 'language code in Discourse'
   LANGUAGE_MAP = {
+    'cy_GB' => 'cy',
     'el_GR' => 'el',
     'es_ES' => 'es',
     'fr_FR' => 'fr',
Next, commit your changes and create a pull request.
:warning: You need to wait for your pull request to be merged if you added an entry to LANGUAGE_MAP. If you didn’t, you can continue right away.
Run script/pull_translations.rb <language_code> in your discourse directory – <language_code> is the code used by Discourse. It will download all translations from Transifex and do some post-processing afterwards.
Transliteration (optional)
Discourse generates slugs from topic titles. Those are the nice looking topic titles in URLs. For example, this topic’s URL contains: /t/how-to-add-a-new-language/14970
But that only works for ASCII characters. You can add transliteration rules for your character set by creating the following file: /config/locales/transliterate.<language_code>.yml
You can take a look at the various existing files (e.g. transliterate.ru.yml) if you need some inspiration.
:bulb: The slug generation method can be configured in the site settings. You don’t need to create transliteration rules if the users in your country are accustomed to encoded slugs or prefer to have no slugs.
You can also change the default slug generation method for your language in site_settings.yml.
Right-to-left (optional)
If the new language is a right-to-left script then you also need to add the <language_code> to the rtl? method in app/helpers/application_helper.rb.
Final checks
Now it’s time to make sure that everything is configured correctly.
Plural rules
Discourse has two files with plural rules – for Ruby and JavaScript. Please verify that the rules match the ones defined in the The Unicode Consortium’s Plural Rules.
  • config/locales/plurals.rb
  • lib/javascripts/locale/<language_code>.js
Language name
The file config/locales/names.yml should contain an entry for your language. Please make sure that the language code exists and that the nativeName is correct. For Welsh it looks like this:
cy:
  nativeName: Cymraeg
Other files
The following files also need to exist:
  • vendor/assets/javascripts/moment-locale/<language_code>.js
:bulb: The language code doesn’t have to match exactly. Only the part before the hyphen must match. So, for Welsh it doesn’t make any difference if the file is named cy-gb.js or cy.js – they are considered the same.
Integration tests
Run the following tests suite to check for known integrity issues:
bundle exec rspec spec/integrity/i18n_spec.rb
bundle exec rspec spec/components/js_locale_helper_spec.rb
It’s also a good idea to check for obvious errors in the translation files as described in How to check locale files for errors.
Live test
Start your Rails server and test that you can change to the new language using the default locale site setting.
Submit your Pull Request
If everything works, commit the files and send us a pull request. :tada:
21 个赞
Can I use a partial translated language?
You mean a language that doesn’t show as 100% complete in Transifex? Yes you can, but there may be missing translations in some places. It won’t break the site, but it won’t look pretty.
Is there a way to copy all translations for a language A into language B, and then work on language B?
I’m working on the Catalan translation, and what would be easiest is to leverage the already-made Spanish translation as a basis (I’m fluent in both langs).
This is untested, but you could try to download the Spanish translation files in Transifex and upload them as Catalan translations.
1 个赞
Oh yes that does make a lot of sense. I will try. Thanks!
Edit: it did work. The YML file transifex generated was slightly broken (couple newlines missing) and could not be uploaded verbatim, but after fixing it I can work with Spanish as a basis. Thanks!
I’ve completly reworked the guide in the first post because a lot has changed over the past couple of years.
Unfortunately adding a new language doesn’t work without a development environment anymore. If you feel that’s too much for you to handle, feel free to ask us to add it for you. But, if you like a challenge, adding a new language could be a great task to get accustomed to Discourse. :wink:
10 个赞
I’ve created a pull request to add Hungarian language. I hope it will be OK. :slight_smile:
4 个赞
Created another pull request to use Hungarian locale.
6 个赞
My PR has merged. Thanks! :metal::tada:
5 个赞
I just started working on completing the Romanian translation over at Transifex. I am unsure about how often the language files in live existing instances of Discourse are being updated. Are they refreshed from Transifex with every launcher app rebuild?
Thank you.
2 个赞
Rebuilding the app container won’t update the translations unless they were updated in our GitHub repository. The translations are usually updated with every release of a new beta version.
2 个赞
From last 45 days we are working hard to translate Hindi (hi) language. Currently we are somewhere 24%
In some translations, we need to cross check them on live site whether they are relevant or not. So please someone add hindi (hi) to discourse so we can continue to make it better.
1 个赞
你好!
是否可以为同一种语言提供多个翻译版本,还是您限制为每种语言仅有一个翻译?
我最近加入了瑞典的一个 Discourse 社区。我认为当前的瑞典语翻译相当不足。它虽然紧跟英文版本,但不够人性化,未能达到我的期望。许多单词和短语可以保留原样(因为它们对普通用户来说并不重要),但也有许多内容需要修改,以便让刚接触社区的新人能够轻松理解
此致,
Niklas
你好,目前添加新语言的指导方针是什么?这些说明已标记为过时,且 pull_translations 脚本已不存在。一旦翻译内容在 Crowdin 中准备好,discourse-translator-bot 会为我们处理所有后续工作吗?
当核心翻译进度达到至少 50% 时,我们将添加新的语言。
1 个赞
