مكون إضافي للمترجم: NotPreloadedError
مرحباً،
أنا أستخدم إضافة المترجم مع LibreTranslate على Bonn.Community. إنها تعمل على مقالات معينة، بينما أعطتني مقالات أخرى رسالة الخطأ هذه.
لقد حاولت إعادة البناء، لكن ذلك لم يساعد.
HasCustomFields::NotPreloadedError (Attempted to access the non preloaded custom field 'post_detected_lang' on the 'Post' class. This is disallowed to prevent N+1 queries.) app/models/concerns/has_cus
app/models/concerns/has_custom_fields.rb:235:in `[]'
plugins/discourse-translator/lib/discourse_translator/guardian_extension.rb:30:in `can_translate?'
plugins/discourse-translator/plugin.rb:47:in `block (2 levels) in activate!'
(eval at /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:467):108:in `_fast_attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:456:in `attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:347:in `as_json'
app/serializers/post_stream_serializer_mixin.rb:67:in `block in posts'
activerecord (7.2.2.1) lib/active_record/relation/delegation.rb:98:in `each'
app/serializers/post_stream_serializer_mixin.rb:60:in `map'
app/serializers/post_stream_serializer_mixin.rb:60:in `posts'
app/serializers/post_stream_serializer_mixin.rb:31:in `post_stream'
(eval at /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:467):3:in `_fast_attributes'
activesupport (7.2.2.1) lib/active_support/json/encoding.rb:23:in `encode'
activesupport (7.2.2.1) lib/active_support/core_ext/object/json.rb:42:in `to_json'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:331:in `to_json'
multi_json (1.15.0) lib/multi_json/adapters/oj.rb:56:in `dump'
multi_json (1.15.0) lib/multi_json/adapter.rb:25:in `dump'
multi_json (1.15.0) lib/multi_json.rb:139:in `dump'
app/controllers/application_controller.rb:528:in `render_json_dump'
app/controllers/topics_controller.rb:1385:in `block (2 levels) in perform_show_response'
actionpack (7.2.2.1) lib/action_controller/metal/mime_responds.rb:224:in `respond_to'
app/controllers/topics_controller.rb:1375:in `perform_show_response'
app/controllers/topics_controller.rb:191:in `show'
actionpack (7.2.2.1) lib/action_controller/metal/basic_implicit_render.rb:8:in `send_action'
actionpack (7.2.2.1) lib/abstract_controller/base.rb:226:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/rendering.rb:193:in `process_action'
actionpack (7.2.2.1) lib/abstract_controller/callbacks.rb:261:in `block in process_action'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:121:in `block in run_callbacks'
app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
i18n (1.14.6) lib/i18n.rb:353:in `with_locale'
app/controllers/application_controller.rb:424:in `with_resolved_locale'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack (7.2.2.1) lib/abstract_controller/callbacks.rb:260:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/rescue.rb:27:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/instrumentation.rb:77:in `block in process_action'
activesupport (7.2.2.1) lib/active_support/notifications.rb:210:in `block in instrument'
activesupport (7.2.2.1) lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport (7.2.2.1) lib/active_support/notifications.rb:210:in `instrument'
actionpack (7.2.2.1) lib/action_controller/metal/instrumentation.rb:76:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.2.2.1) lib/active_record/railties/controller_runtime.rb:39:in `process_action'
actionpack (7.2.2.1) lib/abstract_controller/base.rb:163:in `process'
actionview (7.2.2.1) lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:115:in `block in profile_method'
actionpack (7.2.2.1) lib/action_controller/metal.rb:252:in `dispatch'
actionpack (7.2.2.1) lib/action_controller/metal.rb:335:in `dispatch'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:67:in `dispatch'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:50:in `serve'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:53:in `block in serve'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:133:in `block in find_routes'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:126:in `each'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:126:in `find_routes'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:34:in `serve'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:896:in `call'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack (2.2.10) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.10) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.10) lib/rack/head.rb:12:in `call'
actionpack (7.2.2.1) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
lib/middleware/anonymous_cache.rb:403:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:26:in `call'
rack (2.2.10) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.10) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/callbacks.rb:31:in `block in call'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (7.2.2.1) lib/action_dispatch/middleware/callbacks.rb:30:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/debug_exceptions.rb:31:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/show_exceptions.rb:32:in `call'
logster (2.20.0) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.2.2.1) lib/rails/rack/logger.rb:41:in `call_app'
railties (7.2.2.1) lib/rails/rack/logger.rb:29:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/request_id.rb:33:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
rack (2.2.10) lib/rack/method_override.rb:24:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/executor.rb:16:in `call'
rack (2.2.10) lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:334:in `call'
lib/middleware/processing_request.rb:12:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
lib/middleware/request_tracker.rb:385:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/remote_ip.rb:96:in `call'
railties (7.2.2.1) lib/rails/engine.rb:535:in `call'
railties (7.2.2.1) lib/rails/railtie.rb:226:in `public_send'
railties (7.2.2.1) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.10) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.10) lib/rack/urlmap.rb:58:in `each'
rack (2.2.10) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
info backtrace env
إعجاب واحد (1)
@nat عمل مؤخرًا على المكون الإضافي، أتساءل عما إذا كان هذا مرتبطًا، وسنلقي نظرة.
هل هذه المشكلة جديدة، هل كانت تعمل بشكل جيد سابقًا؟
إعجابَين (2)
هل يمكنك مشاركة إصدار المكون الإضافي الذي تستخدمه؟ يجب أن تكون قادرًا على رؤية الـ sha في صفحة /admin/plugins الخاصة بموقعك، على سبيل المثال 97edd7d في لقطة الشاشة أدناه.
لا يمكنني الجزم، حيث أننا لم نكن نستخدم المكون الإضافي بنشاط لفترة طويلة.
اكتشفت ذلك عندما كنت ألعب بالمكون الإضافي ActivityPub.
0.3.0، 97edd7d
إعجاب واحد (1)
يجب إصلاح هذا الخطأ بالتحديث الجديد - لقد ابتعدنا عن الحقول المخصصة ونستخدم الجداول للترجمات الآن.
إعجاب واحد (1)
تم إغلاق هذا الموضوع تلقائيًا بعد 3 أيام. لم يعد يُسمح بالردود الجديدة.
