Problemen met het vinden van categorieën die een taggroep beperken
PeakProsperity is struggling to move topics between categories due to tag restrictions and wants a GUI feature to easily identify which categories restrict specific tag groups — particularly the “Primary Topic” tag group. Heliosurge suggests using the Data Explorer plugin, but PeakProsperity finds it difficult to locate the relevant data. Heliosurge recommends moving topics one category at a time or creating a cheat sheet, acknowledging the frustration. PeakProsperity proposes turning this into a feature request. JammyDodger suggests checking the tag’s info page, which reveals tag group restrictions. PeakProsperity confirms the “Primary Topic” tag group is involved but can’t find any category explicitly restricting it. JammyDodger then suggests the issue may be the reverse: categories may be set to only allow specific tag groups, unless “Also allow other tags” is checked. PeakProsperity confirms this was the issue — the setting was unchecked in some categories, preventing topics with “Primary Topic” tags from being moved. The solution is to ensure “Also allow other tags” is enabled where needed.
I’m having trouble moving content between categories and have figured out that it’s because there are some tags applied to the content that are restricted. However, I’m having a heck-of-a-time figuring out which category it is that’s restricting the tag. I wish I could go to the Tag Group settings page and view a list of all categories that restrict that tag group to the categories, but there doesn’t seem to be a way to do this. Does anybody know of a way to do this easily without clicking through each and every category and sub-category and looking up the Tag settings? If not, can this be added as a feature request? Thanks.
Not sure, but imagine the data explorer plugin with a query setup might pull the results
I tried that and was having a hard time finding where the information is stored.
As mentioned not sure how the query would need to be setup.
The only thing can recommend is to move topics one category at a time.
Otherwise likely an idea to create a cheat sheet if what categories have tags restricted to them.
I have gone through this issue myself. So do sympathize with the headache.
Okay thanks, well perhaps move this topic into a feature request? I would think there should be a way to provide a GUI interface that provides this information consolidated in the tag group’s settings page.
Do you know which tag is the troublesome one? If so, you can go to the tag’s page and click on the tag wrench to see more info:
(or it’s the :information_source: button if you’re not an admin)
It’s one of two tags, each of which belongs to the “Primary Topic” tag group. This is what I see:
And on the tag group page:
I’m assuming somewhere there is a category that has the “Restrict these tag groups to this category” setting, but I’ve gone through every category manually and cannot find any categories that have the “Primary Topic” tag group specified in this setting.
So, I guess I’m at a loss. I’ve been able to successfully move topics from one category to another so long as they don’t have a “Primary Topic” tag specified, but any that have a “Primary Topic” tag specified cause the topic to not be able to be moved.
Could it be the reverse and you’re only allowed to use tags in that category that you’ve explicitly set?
For instance, for Customization > Plugin we have this:
Without the ‘Also allow other tags’ ticked we could only use the tags in the Resource Status tag group and none of the others.
Bingo - you figured it out. Thanks! I’ll have to go through and make sure that’s checked on other categories.
