Trust level 4 users cannot set topic timers anymore
When we upgraded to 1.9 the trust level 4 users seem to have lost their ability to set timers for topics. So they cannot auto-close topics or close them temporarily. They can close them in a regular manner, though.
This must be a bug or a regression. It cannot be intentional, right?
(We are on 1.9.1)
1 лайк
Possibly, what do you think @tgxworld?
В настоящее время таймеры тем доступны только для сотрудников: см. Scheduling topics for future publication. Я полностью поддерживаю предоставление пользователям TL4 прав на использование таймеров тем, но это будет новая задача Contribute > Feature, а не Contribute > Bug.
Trust level 4 had the feature in 1.8. No doubt about it.
Did it work though? When I tested this back in August the timer didn’t actually do anything when it was triggered:
https://meta.discourse.org/t/how-to-create-a-timed-topic/60731/9?u=jomaxro
We never experienced any problems. Here is a topic that was scheduled to close in 60 minutes by a TL4 user:
1 лайк
Тогда считайте меня в недоумении. Возвращаю это в Contribute > Bug. Я пока помолчу, а настоящий инженер (@tgxworld) посмотрит, когда появится :grimacing:.
6 лайков
@jomaxro Yea topic timers are supposed to be available to admins and users with trust level 4 or higher. Do you recall why we restricted it to staff only?
https://github.com/tgxworld/discourse/commit/e3e6fd6ea0ecf2611738127efc585afbf727d219
5 лайков
It came from this topic: Scheduling topics for future publication. Topic timers were not working for TL4 users when I tested it (timers could be set but nothing would happen when they triggered), so Jeff said to disable it unless it was an easy fix.
4 лайка
Ah icic. I’ll have a look then :slight_smile:
4 лайка
Can you try reproducing this again? I tried locally but the timers were working fine for me. Thank you!
In the mean time, I’ve reverted
https://github.com/discourse/discourse/commit/5a57a454fe713080814736442a6feb4863ec8c70
4 лайка
I can confirm that auto-close, close temporarily, auto-open, open temporarily, schedule publishing, and remind me all work for a TL4 user on try.
However, Auto-Delete does not appear to work.
7 лайков
TL4 users cannot delete topics anyway, couldn’t you just remove auto delete for TL4 since that is the only problem.
5 лайков
This is now fixed by @zogstrip
6 лайков
