Twitter Native Embed
Yes, I do blocked Twitter.com and x.com
But the native embed tweet is not showing. Instead the discourse embed tweet is showing without picture and video.
The plugin works on my old site with 3.2.0 but not new site with 3.3.0
After I edited the post itself. it works. interesting.
After updating Discourse, it seems that this component is broken again.
Anyone experience this, and find a work around?
I also have the same problem. This component does not work on my discourse version 3.5.0.beta9-dev. Anyone can help ? Thanks.
Come here to say the same. This component is borked.
This theme component still works on my absolutely latest forum.
It’s not broken. Maybe we can check if there’s a configuration error?
Still working fine on my Discourse too (also running latest).
running fine here too on latest discourse
I forked the repo, and got it sort of working (it posted the same tweet like 8 times), but just reverted back to your component. Either way, still can’t get it to work; also turned off virtually all components to no avail.
This component works fine in my old 3.4.6 version forum. Same exact configuration. But it doesn’t work on version 3.5.0.beta9-dev
I’ve just updated to 3.5.0.beta9-dev and it still seems to be working here. Not much help I know, but I don’t think Discourse is the problem.
Twitter previews were working without this solution for us at least up to a couple of weeks ago. Not really sure if the break was tied to the new version or not. Is this still the accepted way of ensuring previews of twitter links are working?
I tried installing the plugin and configuring it as instructed but ran into a roadblock.
When I tried to add https://platform.twitter.com to the content security policy script src setting, I get the following error:
An error occurred: content_security_policy_script_src: Value must be either 'unsafe-eval' or 'wasm-unsafe-eval', or in the form '-' where supported hash algorithms are sha256, sha384 or sha512. Ensure that your input is wrapped in single quotation marks.
Hi All… just checking to see if this has been resolved or figured out yet?
Currently running 3.5.2 and if you use x.com it does not work, but if you change it to twitter.com it works!
setting “Block onebox on redirect” fixed it for me
