Unable to change post owner using iOS18.5 with Safari or Chrome
Discourse 3.5.0.beta5-dev (c1b0e8b30b).
Unable to change post owner on iOS18.5 using either the Safari browser or Chrome 137.0.7151.34 (ie, both on the latest browser versions) because the keyboard doesn’t open.
Steps to repro: Pick any post, click the spanner icon, click Change Ownership, click the + sign.
Expected behaviour: Search box opens, keyboard appears, search for a user.
Actual behaviour: Nothing happens when clicking the + sign, the search box does not appear, the keyboard does not open.
We’ve tried two different iOS18 iPhones with Safari, same issue on both phones:
And the issue also occurs on Chrome on iOS18.5 too:
Not tested with Android yet.
I also reported this earlier today :slight_smile:
I think it does work, if you correctly find the box and then type the full username and ‘enter’. :crossed_fingers: (it takes a little leap of faith :slight_smile:)
It does look busted though
On Android I find you need to click on the select box to get the keyboard to pop up and then there is a spot below to type. However at one time when you started to type a name it would give user suggestions. Now it doesn’t seem to see pic for where I click to pull up keyboard.
Thanks for reporting, I put a pri-high on this one, we will have a look this week.
Cool. I was about to post a new topic but your “similar post” warning caught it… it would have said this: “On Discourse Hub app it’s possible to select the posts, and choose “change ownership”, but the dropdown is empty. 3.5.0.beta2-dev. It does work on the browser on a PC.”
@Richie can you still repro this?
Disclaimer: I’m not Richie. :slight_smile:
But this looks like it’s working fine for me now. :+1:
Also confirmed working fine now on 3.5.0.beta8-dev (d9174e7435)
Thanks @j.jaffeux :grin:
Thanks @Richie and @JammyDodger
