I am experiencing some difficulties changing the ownership of a topic to another user. I have done this successfully before but it doesn’t appear to be responding at the moment. Initially I was using my mobile, but I am now using my laptop and experience the same issue.
Select Change Ownership
Enter the username (tested both with and without the @ character, and matching case)
Attempt to click the Change Ownership button
Moving the mouse over the button displays a red, “no entry” icon. I am uncertain whether the username field is supposed to prompt the selective search or just “trust” the value entered. In either case, nothing happens.
I just realized I couldn’t do it either. Actually I can’t change ownership for any post at all: when I type in the new username, nothing happens and the confirmation button stays greyed out.
@_vincent, do you use Discourse hosting or do you self host? If you self host simply update to latest (/admin/upgrade) as this has been fixed on latest. If you’re on our hosting, we are deploying the fix to our customers, so sit tight for a short while.
