I installed discourse successfully but when try to launch the domain I get an error of unable to connect
What i need to check to fix this issue?
Is it a standard installation?
Did you notice any errors during the installation in the console?
I used the discourse on digital ocean.
It’s probably DNS. Did you log in to the server and go through their setup?
If you do a standard install instead of their one-click installer, discourse-setup will attempt to check that you have DNS set up correctly.
