Unable to enter my discourse site
snowdonkiwi reported intermittent access issues to their Discourse site (connect.gamechangersgo.com), receiving an error stating the requested action was not allowed. codinghorror noted the message likely originated outside Discourse and requested a screenshot. snowdonkiwi provided an image, after which Steven successfully accessed the site via the login URL, suggesting potential DNS or app.yml configuration errors. snowdonkiwi initially encountered a 404 error on the login link but later found that clearing browsing history resolved the issue temporarily for themselves and a client, though the root cause remained unclear snowdonkiwi snowdonkiwi. pfaffman recommended enabling HTTPS to prevent ISP interference. Despite initial success, the problem persisted, leading codinghorror to conclude the issue stemmed from a serious DNS or hosting misconfiguration rather than Discourse itself. Ultimately, pfaffman identified the specific cause: the presence of two conflicting A records for the forum, which caused inconsistent resolution of the correct server address.
For the last two days when I try to get into my discourse site this is the message I get: “I’m sorry, your requested action is not allowed. If you have any questions, please contact the server administrator.”
From time to time it works for a little while and then reverts back to this message.
The site is connect.gamechangersgo.com
There doesn’t appear to be anything obvious wrong at the digital ocean end.
Can you post a screenshot? I don’t think this message exists in Discourse so it so coming from elsewhere.
Works for me, i’m redirected to : http://connect.gamechangersgo.com/login
And I have a classic Discourse (I didn’t try to create an account tho)
You might have messed things up on your DNS providers or your app.yml file if you can’t access it
I just tried that link that you were redirected to and this is the message I got: Not Found
The requested URL /login was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
What do I need to do to actually solve it?
I cleared my browsing history and it’s now working. but I’m not sure why it’s not working for people I’ve invited as users though. I’ll see what message they are receiving.
I’d recommend turning on https to reduce the likelihood that problems are not inserted by some internet service between your Discourse and your users.
I’ve tested it myself and it seems to be working now, also for inviting new users. I hope it will continue!
Needing some more help on this one. The only way I’ve found to solve the problem is to clear browsing data. I had one of my clients who also got the same message and when she cleared her browsing data it worked again. I’ve had to do it several times. I don’t known enough to understand what’s going wrong and how to resolve it.
There’s something seriously wrong with your DNS / hosting config; it’s not a Discourse issue per se.
I don’t think we can help you much on this.
Thanks for clarifying that.
Turns out that the problem was that there were two A records for the forum, so some of the time the right address would be returned, but not others.
