Não foi possível configurar permissões na categoria/subcategoria pai
This seems to be a new issue as it was working fine previously.
Here are a couple example structures - it is a common pattern on forums:
  • Learning Resources - parent category that everyone can see but nobody can post in
    • Books - sub cat where staff can create/see/reply and everyone else can see/reply
    • Courses - same as above
    • etc
Aim of the above is to force use of sub-categories and the parent category is used to keep them all neatly together, i.e to act as a ‘parent’ category.
Another slightly different example:
  • Parent Category (can be seen by various groups, usually all those who can access the below, but can not be posted in)
    • Sub-cat 1 - user group 1 can create/see/reply
    • Sub-cat 2 - user group 2 can create/see/reply
    • Sub-cat 3 - user group 3 can create/see/reply
    • etc
Again the parent category is not to be posted in - it is to act purely as a parent for the sub-categories. The sub-categories can only be seen and posted in by those groups specified in the permissions. This is again to keep the (sub) categories neatly organised.
Trying to add a new sub-category and then a new user group to the sub-cat (where I try to allow that new user group to See the parent category) I get:
Any group that is allowed to access a subcategory must also be allowed to access the parent category.
Yet this is the parent category.
Anyone know what’s going on?
1 curtida
Could this be related to your recent work @maja ?
4 curtidas
Bug where you couldn’t add permissions to sub-category even though parent category is accessible by everyone was fixed few weeks ago (FIX: any subcategory permissions are valid if everyone has access to … · discourse/discourse@fea5d4f · GitHub)
You have to make sure group 1, group 2 etc. have permissions to see parent category before adding them to sub-categories.
I improved error message so it’s clearer now which groups only have access to sub-category and should be added to parent category:
7 curtidas
Thanks, this should help a lot!
4 curtidas
Ah that’s very helpful, thanks!
It appears I had a parent category for staff forums but the ‘staff’ group wasn’t able to ‘see’ it! I wasn’t actually using the staff group for the other sub-cats hence why it didn’t click. Thanks again Maja!
2 curtidas
This topic was automatically closed after 28 hours. New replies are no longer allowed.
