Permissions for subcategories
thorbenegberts reported a potential bug in Discourse 1.6.0.beta12 where members of group B encounter an error when navigating to a parent category that contains a subcategory with more permissive visibility settings than the parent. While group B can access specific topics in the new subcategory via direct links, the topic list within the parent category fails to load for them. cpradio suggested this behavior is documented in a previous discussion regarding subcategories with more permissive permissions than their parents. thorbenegberts confirmed this by referencing a statement from codinghorror indicating that Discourse does not currently support creating subcategories with permissions more open than the parent category. riking added a clarification that this restriction specifically applies to the “see” permission, noting that post creation can still be restricted at the parent level independently.
Hi there,
I wonder if this is a bug or feature :slight_smile:
Let’s assume I’ve got user group A and group B.
We’ve got an internal category with some subcategories. Both the category and its subcategories are only visible to group A.
Now I create a new subcategory that is visible to both A and B. Members of group B now get this errors as they navigate to this category (/c/<categoryname>/):
However, they are able to view topics in this subcategory if they navigate there directly (via link). This error occurs only in the topic list.
(Discourse 1.6.0.beta12 - GitHub - discourse/discourse: A platform for community discussion. Free, open, simple. · GitHub version 1f12e41029f2531904d8600372625e360f87b8fa, hosted instance forum.plentymarkets.com)
I think you are referring to this?
https://meta.discourse.org/t/sub-category-more-permissive-than-parent-category-problem/22793
I was looking for this statement. Thank you.
Note that only applies to the “see” permission - you can still restrict post creation in the parent.
