I am trying to start bundle exec sidekiq and it’s failing. I need help debugging this.
The app is up to date and I haven’t seen anyone mentioning this issue. I haven’t updated the gems. I’ve uninstalled the Plugin I was developing in case it was provoking it to crash (it was drawing a route) but I keep getting the same error.
Does this have something to do with my local Ruby (as it’s complaining from my .rvm folder about Unable to autoload constant Version) or is it related to my local app (it says it’s expecting Discourse to define Version)?
Logs look like this:
➜  discourse git:(master) ✗ bundle exec sidekiq
2017-08-24T05:24:15.125Z 8881 TID-ovgo0oyhk INFO: Booting Sidekiq 5.0.3 with redis options {:host=>"localhost", :port=>6379, :namespace=>"sidekiq", :id=>"Sidekiq-server-PID-8881", :url=>nil}
/Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/dependencies.rb:495:in `load_missing_constant': Unable to autoload constant Version, expected /Users/jlijo/Documents/discourse/lib/version.rb to define it (LoadError)
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/bootsnap-1.0.0/lib/bootsnap/load_path_cache/core_ext/active_support.rb:53:in `block in load_missing_constant'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/bootsnap-1.0.0/lib/bootsnap/load_path_cache/core_ext/active_support.rb:6:in `with_bootsnap_fallback'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/bootsnap-1.0.0/lib/bootsnap/load_path_cache/core_ext/active_support.rb:53:in `load_missing_constant'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/dependencies.rb:184:in `const_missing'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/inflector/methods.rb:261:in `const_get'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/inflector/methods.rb:261:in `block in constantize'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/inflector/methods.rb:259:in `each'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/inflector/methods.rb:259:in `inject'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/inflector/methods.rb:259:in `constantize'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/core_ext/string/inflections.rb:66:in `constantize'
	from /Users/jlijo/Documents/discourse/config/initializers/100-sidekiq.rb:19:in `block (2 levels) in <main>'
	from /Users/jlijo/Documents/discourse/config/initializers/100-sidekiq.rb:18:in `each'
	from /Users/jlijo/Documents/discourse/config/initializers/100-sidekiq.rb:18:in `block in <main>'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/rails_multisite-1.0.6/lib/rails_multisite/connection_management.rb:126:in `block in each_connection'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/rails_multisite-1.0.6/lib/rails_multisite/connection_management.rb:124:in `each'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/rails_multisite-1.0.6/lib/rails_multisite/connection_management.rb:124:in `each_connection'
	from /Users/jlijo/Documents/discourse/config/initializers/100-sidekiq.rb:17:in `<main>'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/bootsnap-1.0.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `load'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/dependencies.rb:268:in `block in load'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/dependencies.rb:240:in `load_dependency'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/dependencies.rb:268:in `load'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/engine.rb:652:in `block in load_config_initializer'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/notifications.rb:166:in `instrument'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/engine.rb:651:in `load_config_initializer'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/engine.rb:616:in `block (2 levels) in <class:Engine>'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/engine.rb:615:in `each'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/engine.rb:615:in `block in <class:Engine>'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/initializable.rb:30:in `instance_exec'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/initializable.rb:30:in `run'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/initializable.rb:55:in `block in run_initializers'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:228:in `block in tsort_each'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:422:in `block (2 levels) in each_strongly_connected_component_from'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:431:in `each_strongly_connected_component_from'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:421:in `block in each_strongly_connected_component_from'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/initializable.rb:44:in `each'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/initializable.rb:44:in `tsort_each_child'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:415:in `call'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:415:in `each_strongly_connected_component_from'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:349:in `block in each_strongly_connected_component'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:347:in `each'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:347:in `call'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:347:in `each_strongly_connected_component'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:226:in `tsort_each'
	from /Users/jlijo/.rvm/rubies/ruby-2.4.0-turbo/lib/ruby/2.4.0/tsort.rb:205:in `tsort_each'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/initializable.rb:54:in `run_initializers'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/application.rb:352:in `initialize!'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/railtie.rb:194:in `public_send'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/railties-4.2.9/lib/rails/railtie.rb:194:in `method_missing'
	from /Users/jlijo/Documents/discourse/config/environment.rb:5:in `<main>'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/bootsnap-1.0.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:17:in `require'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/dependencies.rb:274:in `block in require'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/activesupport-4.2.9/lib/active_support/dependencies.rb:274:in `require'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/sidekiq-5.0.3/lib/sidekiq/cli.rb:254:in `boot_system'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/sidekiq-5.0.3/lib/sidekiq/cli.rb:54:in `run'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/gems/sidekiq-5.0.3/bin/sidekiq:12:in `<top (required)>'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/bin/sidekiq:23:in `load'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/bin/sidekiq:23:in `<main>'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/bin/ruby_executable_hooks:15:in `eval'
	from /Users/jlijo/.rvm/gems/ruby-2.4.0-turbo/bin/ruby_executable_hooks:15:in `<main>'
