"unanswered" button no longer works
Hi there,
I use the “unanswered” button on my forum (), and it has stopped working. I noticed the glitch on November 18, which is when I switched the forum’s “home” view to “categories with featured topics”. “Latest” and “top” buttons still function as expected.
Advice on how to fix it?
Thanks,
Jessica
Sure @techapj can assist.
The “unanswered” navigation button on your site which was pointing at latest page with max_posts=1 parameter broke because of the “top menu” setting change. The custom JS (adding that button) needed to be amended as well.
I just fixed the JS code, “unanswered” navigation button should be working fine now.
Awesome. Thank you very much!
At the risk of this being revived, the same thing happened again. Our “unanswered” nav button was working until recently, pointing to /latest?max_posts=1 and now it shows the below
There was a bug here, but it is now fixed. Updating to the latest version should solve the problem:
https://github.com/discourse/discourse/commit/937ab3f21327ded989781dab6204c031834c6686
Thanks for the quick response
