Uncaught TypeError: Cannot read property 'apply' of undefined
A bug report discusses an Uncaught TypeError: Cannot read property 'apply' of undefined error when saving theme component settings in Discourse. Users md-misko and MarcP describe the issue occurring on a fresh install with the latest version (2cb805a683), where clicking the green check button fails to save changes. vinothkannans notes that the fix was included in a later commit (8d69944) and advises upgrading. md-misko confirms that the fix resolves the issue and suggests closing the topic, clarifying that MarcP’s related error (on default category/tag watching) is separate.
When trying to change theme component setting, clicking the green check button produces the following error, changes are not saved (Category Icons and Tag Icons):
Url: https://forum.url/assets/ember_jquery-1d91c694d903342adc8cb39c93a87ce4c3259ee8cee5ab61289c257be5708f23.js
Line: 1
Column: 490273
Window Location: https://forum.url/admin/customize/themes/4
Update to latest via /admin/upgrade and try again
Already on latest, fresh install, no customizations or plugins other than these two components installed.
Having a similar situation here:
Uncaught TypeError: Cannot read property ‘categories’ of undefined
When trying to save: default categories watching
I have no repro on latest for any of the two issues reported in this topic.
Please be sure:
  • you are on master
  • you try with safe-mode if possible
  • give a very detailed repro if still happening
I am on tests-passed - did a rebuild already. Safe mode still has the issue.
(2cb805a683)
Anonymized error log:
Reproduce? Nothing happens when i select a category as default watch. Red cross makes it undo and green checkmark does not do anything (it should ask if I want to apply to old users, it works on another forum I installed).
Edit: Do you want me to open a topic for this? Or you can just move this post.
Repro steps:
  • install theme component
  • enable component for default theme
  • select component (Category Icons)
  • remove existing entry from setting: category icon list
  • click green check button next to the setting
  • error is logged, changes are not saved (green and red button remain on screen)
Backtrace:
    at e.t._join (https://forum.url/assets/ember_jquery-1d91c694d903342adc8cb39c93a87ce4c3259ee8cee5ab61289c257be5708f23.js:1:490273)
    at e.t.join (https://forum.url/assets/ember_jquery-1d91c694d903342adc8cb39c93a87ce4c3259ee8cee5ab61289c257be5708f23.js:1:487153)
    at p (https://forum.url/assets/ember_jquery-1d91c694d903342adc8cb39c93a87ce4c3259ee8cee5ab61289c257be5708f23.js:1:353112)
    at https://forum.url/assets/ember_jquery-1d91c694d903342adc8cb39c93a87ce4c3259ee8cee5ab61289c257be5708f23.js:1:152256
    at r (https://forum.url/assets/ember_jquery-1d91c694d903342adc8cb39c93a87ce4c3259ee8cee5ab61289c257be5708f23.js:1:340782)
    at https://forum.url/assets/ember_jquery-1d91c694d903342adc8cb39c93a87ce4c3259ee8cee5ab61289c257be5708f23.js:1:152201
    at t.click (https://forum.url/assets/application-1beed43f1604869d65e7d466de8cb9119afcf1cbbc2eae42c98ae8f7a5d0edf9.js:1:933743)
    at trigger (https://forum.url/assets/ember_jquery-1d91c694d903342adc8cb39c93a87ce4c3259ee8cee5ab61289c257be5708f23.js:1:312409)
    at t.e [as trigger] (https://forum.url/assets/ember_jquery-1d91c694d903342adc8cb39c93a87ce4c3259ee8cee5ab61289c257be5708f23.js:1:291192)
    at e.t._run (https://forum.url/assets/ember_jquery-1d91c694d903342adc8cb39c93a87ce4c3259ee8cee5ab61289c257be5708f23.js:1:490423)
My error is happening on all default settings in admin for watching categories and tags.
Both of you are one commit behind the fix. You should be in at least #8d69944.
Please refer to topic below, this containts newer information about my issue.
Okay. But, if you are in 2cb805a683 still you have to upgrade to the latest version to fix the issue (which is reported in OP) in theme components.
I understand what you are saying. In my test env I am on the newest build. Issue is still there. My error is different as the one in this OP. OP should confirm if his error is fixed or not.
There is a bit of confusion and an unintentional hijacking of this topic for seemingly similar but unrelated problem.
When this issue was reported #2cb805a683 was the latest version.
I can confirm that commit #8d69944 indeed fixes the issue in the OP and this topic can be closed.
