I was trying to run rspec on plugins, and this is what I got:
It seems to be introduced here:
It might miss base.attribute :chat_send_shortcut, :integer, default: 0?
I ran into this same issue adding a new enum. Turns out I had to explicitly run the plugin migrations for the test environment:
RAILS_ENV=test LOAD_PLUGINS=1 bin/rails db:migrate
Oh, interesting. I thought db:migrate would include the plugins by default.
Indeed, I had quite a few migrations awaiting for the plugins on RAILS_ENV=test.
The error is gone now, thanks!
EDIT:
Actually, if you use RAILS_ENV=test bin/rake db:migrate, notice the “bin/”, it does set the LOAD_PLUGINS to 1.
You can see the content of bin/rake:
if ENV['RAILS_ENV'] == 'test' && ENV['LOAD_PLUGINS'].nil?
if ARGV.include?('db:migrate') || ARGV.include?('parallel:migrate')
STDERR.puts "You are attempting to run migrations in your test environment and are not loading plugins, setting LOAD_PLUGINS to 1"
ENV['LOAD_PLUGINS'] = '1'
At some point I’ve probably stopped typing bin/ out of laziness
