Salut !
Nous utilisons Discourse sur community.museomix.org depuis plusieurs années.
Mais je rencontre un problème étrange lorsque je reconstruis le conteneur, il échoue avec ce message :
undefined method `deprecated?' for nil:NilClass
Voici la sortie complète de discourse-doctor lors de la reconstruction, au cas où cela pourrait aider :
DISCOURSE DOCTOR Fri Jan 13 03:57:02 PM EST 2023
OS: Linux Community 3.13.0-52-generic #85-Ubuntu SMP Wed Apr 29 16:44:17 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Found containers/app.yml
==================== YML SETTINGS ====================
DISCOURSE_HOSTNAME=community.museomix.org
SMTP_ADDRESS=
DEVELOPER_EMAILS=foo@foo.com
SMTP_PASSWORD=
SMTP_PORT=587
SMTP_USER_NAME=
LETSENCRYPT_ACCOUNT_EMAIL='foo@foo.com' #LETSENCRYPT_ACCOUNT_EMAIL
==================== DOCKER INFO ====================
DOCKER VERSION: Docker version 20.10.22, build 3a2c30b
DOCKER PROCESSES (docker ps -a)
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
f264bbb9a068 hello-world "/hello" 9 minutes ago Exited (0) 9 minutes ago sharp_pare
6cf48eb9791f local_discourse/app "/sbin/boot" 4 days ago Exited (6) 12 minutes ago app
==================== SERIOUS PROBLEM!!!! ====================
app not running!
Attempting to rebuild
==================== REBUILD LOG ====================
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
2.0.20221221-0050: Pulling from discourse/base
Digest: sha256:7ac6489e34a0f40f32457bffaa331940a98447b46451a6a1279a79868ee5420b
Status: Image is up to date for discourse/base:2.0.20221221-0050
docker.io/discourse/base:2.0.20221221-0050
/usr/local/lib/ruby/gems/3.1.0/gems/pups-1.1.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2023-01-13T20:57:14.087807 #1] INFO -- : Reading from stdin
I, [2023-01-13T20:57:14.092670 #1] INFO -- : > locale-gen $LANG && update-locale
I, [2023-01-13T20:57:14.350231 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2023-01-13T20:57:14.350649 #1] INFO -- : > mkdir -p /shared/postgres_run
I, [2023-01-13T20:57:14.355407 #1] INFO -- :
I, [2023-01-13T20:57:14.356158 #1] INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2023-01-13T20:57:14.359173 #1] INFO -- :
I, [2023-01-13T20:57:14.359515 #1] INFO -- : > chmod 775 /shared/postgres_run
I, [2023-01-13T20:57:14.361742 #1] INFO -- :
I, [2023-01-13T20:57:14.362373 #1] INFO -- : > rm -fr /var/run/postgresql
I, [2023-01-13T20:57:14.364979 #1] INFO -- :
I, [2023-01-13T20:57:14.365387 #1] INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2023-01-13T20:57:14.368409 #1] INFO -- :
I, [2023-01-13T20:57:14.368699 #1] INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2023/01/13 20:57:14 socat[18] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2023-01-13T20:57:14.388890 #1] INFO -- :
I, [2023-01-13T20:57:14.389245 #1] INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2023-01-13T20:57:14.392196 #1] INFO -- :
I, [2023-01-13T20:57:14.392487 #1] INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2023-01-13T20:57:14.395147 #1] INFO -- :
I, [2023-01-13T20:57:14.395454 #1] INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-01-13T20:57:14.398215 #1] INFO -- :
I, [2023-01-13T20:57:14.398653 #1] INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-01-13T20:57:14.400967 #1] INFO -- :
I, [2023-01-13T20:57:14.417469 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2023-01-13T20:57:14.428618 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2023-01-13T20:57:14.434745 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2023-01-13T20:57:14.439755 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2023-01-13T20:57:14.440185 #1] INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2023-01-13T20:57:15.206364 #1] INFO -- :
I, [2023-01-13T20:57:15.206661 #1] INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2023-01-13T20:57:15.208870 #1] INFO -- :
I, [2023-01-13T20:57:15.209144 #1] INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2023-01-13T20:57:15.231061 #1] INFO -- :
I, [2023-01-13T20:57:15.231632 #1] INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2023-01-13T20:57:15.234995 #1] INFO -- :
I, [2023-01-13T20:57:15.235497 #1] INFO -- : > /root/upgrade_postgres
I, [2023-01-13T20:57:15.243749 #1] INFO -- :
I, [2023-01-13T20:57:15.244196 #1] INFO -- : > rm /root/upgrade_postgres
I, [2023-01-13T20:57:15.247241 #1] INFO -- :
I, [2023-01-13T20:57:15.249344 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-13T20:57:15.250389 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-13T20:57:15.251310 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-13T20:57:15.251962 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-13T20:57:15.252492 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-13T20:57:15.253049 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-13T20:57:15.253648 #1] INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2023-01-13T20:57:15.258895 #1] INFO -- :
I, [2023-01-13T20:57:15.259524 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-13T20:57:15.260000 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-13T20:57:15.260759 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-13T20:57:15.261995 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/13/main/pg_hba.conf
I, [2023-01-13T20:57:15.262518 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-01-13T20:57:15.263083 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-01-13T20:57:15.263399 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2023-01-13T20:57:15.264639 #1] INFO -- : > sleep 5
2023-01-13 20:57:15.347 UTC [41] LOG: starting PostgreSQL 13.9 (Debian 13.9-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2023-01-13 20:57:15.348 UTC [41] LOG: listening on IPv4 address "0.0.0.0", port 5432
2023-01-13 20:57:15.348 UTC [41] LOG: listening on IPv6 address "::", port 5432
2023-01-13 20:57:15.350 UTC [41] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-01-13 20:57:15.356 UTC [44] LOG: database system was shut down at 2023-01-13 20:52:18 UTC
2023-01-13 20:57:15.364 UTC [41] LOG: database system is ready to accept connections
I, [2023-01-13T20:57:20.301579 #1] INFO -- :
I, [2023-01-13T20:57:20.301874 #1] INFO -- : > su postgres -c 'createdb discourse' || true
2023-01-13 20:57:20.394 UTC [54] postgres@postgres ERROR: database "discourse" already exists
2023-01-13 20:57:20.394 UTC [54] postgres@postgres STATEMENT: CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR: database "discourse" already exists
I, [2023-01-13T20:57:20.396968 #1] INFO -- :
I, [2023-01-13T20:57:20.397470 #1] INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2023-01-13 20:57:20.471 UTC [58] postgres@discourse ERROR: role "discourse" already exists
2023-01-13 20:57:20.471 UTC [58] postgres@discourse STATEMENT: create user discourse;
I, [2023-01-13T20:57:20.474321 #1] INFO -- :
I, [2023-01-13T20:57:20.474802 #1] INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2023-01-13T20:57:20.547104 #1] INFO -- : GRANT
I, [2023-01-13T20:57:20.547549 #1] INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2023-01-13T20:57:20.607661 #1] INFO -- : ALTER SCHEMA
I, [2023-01-13T20:57:20.608077 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE: extension "hstore" already exists, skipping
I, [2023-01-13T20:57:20.668785 #1] INFO -- : CREATE EXTENSION
I, [2023-01-13T20:57:20.669132 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE: extension "pg_trgm" already exists, skipping
I, [2023-01-13T20:57:20.729483 #1] INFO -- : CREATE EXTENSION
I, [2023-01-13T20:57:20.730252 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2023-01-13T20:57:20.790467 #1] INFO -- : CREATE EXTENSION
I, [2023-01-13T20:57:20.790873 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2023-01-13T20:57:20.850443 #1] INFO -- : CREATE EXTENSION
I, [2023-01-13T20:57:20.850882 #1] INFO -- : > sudo -u postgres psql discourse
I, [2023-01-13T20:57:20.854666 #1] INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2023-01-13T20:57:20.926407 #1] INFO -- : File > /var/lib/postgresql/take-database-backup chmod: +x chown: postgres:postgres
I, [2023-01-13T20:57:20.931661 #1] INFO -- : File > /var/spool/cron/crontabs/postgres chmod: chown:
I, [2023-01-13T20:57:20.932121 #1] INFO -- : > echo postgres installed!
I, [2023-01-13T20:57:20.935624 #1] INFO -- : postgres installed!
I, [2023-01-13T20:57:20.942545 #1] INFO -- : File > /etc/service/redis/run chmod: +x chown:
I, [2023-01-13T20:57:20.948661 #1] INFO -- : File > /etc/service/redis/log/run chmod: +x chown:
I, [2023-01-13T20:57:20.953584 #1] INFO -- : File > /etc/runit/3.d/10-redis chmod: +x chown:
I, [2023-01-13T20:57:20.955243 #1] INFO -- : Replacing daemonize yes with in /etc/redis/redis.conf
I, [2023-01-13T20:57:20.956050 #1] INFO -- : Replacing (?-mix:^pidfile.*$) with in /etc/redis/redis.conf
I, [2023-01-13T20:57:20.957307 #1] INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2023-01-13T20:57:20.961081 #1] INFO -- :
I, [2023-01-13T20:57:20.961686 #1] INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2023-01-13T20:57:20.962359 #1] INFO -- : Replacing (?-mix:^bind .*$) with in /etc/redis/redis.conf
I, [2023-01-13T20:57:20.963776 #1] INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2023-01-13T20:57:20.965043 #1] INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2023-01-13T20:57:20.966468 #1] INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2023-01-13T20:57:20.967502 #1] INFO -- : > echo redis installed
I, [2023-01-13T20:57:20.970150 #1] INFO -- : redis installed
I, [2023-01-13T20:57:20.970503 #1] INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2023-01-13T20:57:20.975752 #1] INFO -- : logfile ""
I, [2023-01-13T20:57:20.976133 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-01-13T20:57:20.977296 #1] INFO -- : > sleep 10
102:C 13 Jan 2023 20:57:21.392 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
102:C 13 Jan 2023 20:57:21.392 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=102, just started
102:C 13 Jan 2023 20:57:21.392 # Configuration loaded
102:M 13 Jan 2023 20:57:21.393 * monotonic clock: POSIX clock_gettime
102:M 13 Jan 2023 20:57:21.394 * Running mode=standalone, port=6379.
102:M 13 Jan 2023 20:57:21.394 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
102:M 13 Jan 2023 20:57:21.395 # Server initialized
102:M 13 Jan 2023 20:57:21.395 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
102:M 13 Jan 2023 20:57:21.395 # WARNING You have Transparent Huge Pages (THP) support enabled in your kernel. This will create latency and memory usage issues with Redis. To fix this issue run the command 'echo madvise > /sys/kernel/mm/transparent_hugepage/enabled' as root, and add it to your /etc/rc.local in order to retain the setting after a reboot. Redis must be restarted after THP is disabled (set to 'madvise' or 'never').
102:M 13 Jan 2023 20:57:21.396 * Loading RDB produced by version 7.0.7
102:M 13 Jan 2023 20:57:21.397 * RDB age 303 seconds
102:M 13 Jan 2023 20:57:21.397 * RDB memory usage when created 12.28 Mb
102:M 13 Jan 2023 20:57:21.434 * Done loading RDB, keys loaded: 12352, keys expired: 0.
102:M 13 Jan 2023 20:57:21.435 * DB loaded from disk: 0.039 seconds
102:M 13 Jan 2023 20:57:21.435 * Ready to accept connections
I, [2023-01-13T20:57:30.983477 #1] INFO -- :
I, [2023-01-13T20:57:30.983658 #1] INFO -- : > thpoff echo "thpoff is installed!"
I, [2023-01-13T20:57:30.988243 #1] INFO -- : thpoff is installed!
I, [2023-01-13T20:57:30.988586 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2023-01-13T20:57:32.884024 #1] INFO -- :
I, [2023-01-13T20:57:32.884607 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2023-01-13T20:57:32.991609 #1] INFO -- :
I, [2023-01-13T20:57:32.992131 #1] INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2023-01-13T20:57:33.085605 #1] INFO -- :
I, [2023-01-13T20:57:33.086528 #1] INFO -- : > rm -f /etc/cron.d/anacron
I, [2023-01-13T20:57:33.089851 #1] INFO -- :
I, [2023-01-13T20:57:33.092981 #1] INFO -- : File > /etc/cron.d/anacron chmod: chown:
I, [2023-01-13T20:57:33.098976 #1] INFO -- : File > /etc/runit/1.d/copy-env chmod: +x chown:
I, [2023-01-13T20:57:33.104108 #1] INFO -- : File > /etc/service/unicorn/run chmod: +x chown:
I, [2023-01-13T20:57:33.109588 #1] INFO -- : File > /etc/service/nginx/run chmod: +x chown:
I, [2023-01-13T20:57:33.115297 #1] INFO -- : File > /etc/runit/3.d/01-nginx chmod: +x chown:
I, [2023-01-13T20:57:33.120367 #1] INFO -- : File > /etc/runit/3.d/02-unicorn chmod: +x chown:
I, [2023-01-13T20:57:33.120696 #1] INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2023-01-13T20:57:33.121020 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-01-13T20:57:33.123102 #1] INFO -- : > cd /var/www/discourse && git reset --hard
129:C 13 Jan 2023 20:57:33.133 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
129:C 13 Jan 2023 20:57:33.133 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=129, just started
129:C 13 Jan 2023 20:57:33.133 # Configuration loaded
129:M 13 Jan 2023 20:57:33.134 * monotonic clock: POSIX clock_gettime
129:M 13 Jan 2023 20:57:33.134 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
129:M 13 Jan 2023 20:57:33.134 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (32637/32637), done.
I, [2023-01-13T20:57:47.114566 #1] INFO -- : HEAD is now at e775ed1c DEV: Properly include spec examples (#19532)
I, [2023-01-13T20:57:47.115003 #1] INFO -- : > cd /var/www/discourse && git clean -f
I, [2023-01-13T20:57:47.360028 #1] INFO -- :
I, [2023-01-13T20:57:47.360436 #1] INFO -- : > cd /var/www/discourse && git remote set-branches --add origin main
I, [2023-01-13T20:57:47.366539 #1] INFO -- :
I, [2023-01-13T20:57:47.366909 #1] INFO -- : > cd /var/www/discourse && git remote set-branches origin tests-passed
I, [2023-01-13T20:57:47.371415 #1] INFO -- :
I, [2023-01-13T20:57:47.371771 #1] INFO -- : > cd /var/www/discourse && git fetch --depth 1 origin tests-passed
From https://github.com/discourse/discourse
* branch tests-passed -> FETCH_HEAD
* [new branch] tests-passed -> origin/tests-passed
I, [2023-01-13T20:57:50.960336 #1] INFO -- :
I, [2023-01-13T20:57:50.960667 #1] INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2023-01-13T20:57:52.014831 #1] INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2023-01-13T20:57:52.015196 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2023-01-13T20:57:52.019694 #1] INFO -- :
I, [2023-01-13T20:57:52.020014 #1] INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2023-01-13T20:57:52.023449 #1] INFO -- :
I, [2023-01-13T20:57:52.023752 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2023-01-13T20:57:52.026874 #1] INFO -- :
I, [2023-01-13T20:57:52.027135 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2023-01-13T20:57:52.030196 #1] INFO -- :
I, [2023-01-13T20:57:52.030447 #1] INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2023-01-13T20:57:52.034623 #1] INFO -- :
I, [2023-01-13T20:57:52.034894 #1] INFO -- : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2023-01-13T20:57:52.038374 #1] INFO -- :
I, [2023-01-13T20:57:52.038629 #1] INFO -- : > cd /var/www/discourse && bash -c "touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2023-01-13T20:57:52.044961 #1] INFO -- :
I, [2023-01-13T20:57:52.045215 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2023-01-13T20:57:52.050783 #1] INFO -- :
I, [2023-01-13T20:57:52.051070 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/{uploads,backups}"
I, [2023-01-13T20:57:52.056515 #1] INFO -- :
I, [2023-01-13T20:57:52.056781 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/{uploads,backups} /var/www/discourse/public"
I, [2023-01-13T20:57:52.062351 #1] INFO -- :
I, [2023-01-13T20:57:52.062666 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/tmp/{backups,restores}"
I, [2023-01-13T20:57:52.068265 #1] INFO -- :
I, [2023-01-13T20:57:52.068578 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2023-01-13T20:57:52.073527 #1] INFO -- :
I, [2023-01-13T20:57:52.074212 #1] INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2023-01-13T20:57:52.117534 #1] INFO -- :
I, [2023-01-13T20:57:52.117960 #1] INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2023-01-13T20:57:52.123169 #1] INFO -- :
I, [2023-01-13T20:57:52.123948 #1] INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2023-01-13T20:57:52.124352 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2023-01-13T20:57:54.360521 #1] INFO -- :
I, [2023-01-13T20:57:54.361091 #1] INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2023-01-13T20:57:54.366047 #1] INFO -- :
I, [2023-01-13T20:57:54.366535 #1] INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2023-01-13T20:57:54.369289 #1] INFO -- :
I, [2023-01-13T20:57:54.369615 #1] INFO -- : > mkdir -p /var/nginx/cache
I, [2023-01-13T20:57:54.372453 #1] INFO -- :
I, [2023-01-13T20:57:54.373095 #1] INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2023-01-13T20:57:54.373542 #1] INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2023-01-13T20:57:54.374208 #1] INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2023-01-13T20:57:54.374683 #1] INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2023-01-13T20:57:54.375248 #1] INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2023-01-13T20:57:54.375540 #1] INFO -- : > echo "done configuring web"
I, [2023-01-13T20:57:54.377017 #1] INFO -- : done configuring web
I, [2023-01-13T20:57:54.377367 #1] INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
ERROR: Loading command: install (RuntimeError)
failed to get urandom
/usr/local/lib/ruby/3.1.0/securerandom.rb:75:in `urandom'
/usr/local/lib/ruby/3.1.0/securerandom.rb:75:in `singleton class'
/usr/local/lib/ruby/3.1.0/securerandom.rb:42:in `<module:SecureRandom>'
/usr/local/lib/ruby/3.1.0/securerandom.rb:41:in `<top (required)>'
<internal:/usr/local/lib/ruby/3.1.0/rubygems/core_ext/kernel_require.rb>:85:in `require'
/usr/local/lib/ruby/3.1.0/resolv.rb:8:in `<top (required)>'
/usr/local/lib/ruby/3.1.0/net/http.rb:25:in `<top (required)>'
/usr/local/lib/ruby/3.1.0/rubygems/request.rb:2:in `<top (required)>'
/usr/local/lib/ruby/3.1.0/rubygems/remote_fetcher.rb:3:in `require_relative'
/usr/local/lib/ruby/3.1.0/rubygems/remote_fetcher.rb:3:in `<top (required)>'
/usr/local/lib/ruby/3.1.0/rubygems/spec_fetcher.rb:2:in `require_relative'
/usr/local/lib/ruby/3.1.0/rubygems/spec_fetcher.rb:2:in `<top (required)>'
/usr/local/lib/ruby/3.1.0/rubygems/dependency_installer.rb:6:in `require_relative'
/usr/local/lib/ruby/3.1.0/rubygems/dependency_installer.rb:6:in `<top (required)>'
/usr/local/lib/ruby/3.1.0/rubygems/commands/install_command.rb:4:in `require_relative'
/usr/local/lib/ruby/3.1.0/rubygems/commands/install_command.rb:4:in `<top (required)>'
/usr/local/lib/ruby/3.1.0/rubygems/command_manager.rb:228:in `load_and_instantiate'
/usr/local/lib/ruby/3.1.0/rubygems/command_manager.rb:135:in `[]'
/usr/local/lib/ruby/3.1.0/rubygems/command_manager.rb:201:in `find_command'
/usr/local/lib/ruby/3.1.0/rubygems/command_manager.rb:183:in `process_args'
/usr/local/lib/ruby/3.1.0/rubygems/command_manager.rb:149:in `run'
/usr/local/lib/ruby/3.1.0/rubygems/gem_runner.rb:51:in `run'
/usr/local/bin/gem:21:in `<main>'
ERROR: While executing gem ... (NoMethodError)
cmd.deprecation_warning if cmd.deprecated?
/usr/local/lib/ruby/3.1.0/rubygems/command_manager.rb:184:in `process_args'
I, [2023-01-13T20:57:54.876405 #1] INFO -- :
I, [2023-01-13T20:57:54.876935 #1] INFO -- : Terminating async processes
I, [2023-01-13T20:57:54.877081 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 41
I, [2023-01-13T20:57:54.877224 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 102
102:signal-handler (1673643474) Received SIGTERM scheduling shutdown...
2023-01-13 20:57:54.877 UTC [41] LOG: received fast shutdown request
2023-01-13 20:57:54.881 UTC [41] LOG: aborting any active transactions
2023-01-13 20:57:54.886 UTC [41] LOG: background worker "logical replication launcher" (PID 50) exited with exit code 1
2023-01-13 20:57:54.887 UTC [45] LOG: shutting down
2023-01-13 20:57:54.907 UTC [41] LOG: database system is shut down
102:M 13 Jan 2023 20:57:54.944 # User requested shutdown...
102:M 13 Jan 2023 20:57:54.944 * Saving the final RDB snapshot before exiting.
102:M 13 Jan 2023 20:57:55.006 * DB saved on disk
102:M 13 Jan 2023 20:57:55.006 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock) failed with return #<Process::Status: pid 231 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.1.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"web", "cmd"=>["gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,\"\"); print $0 }' Gemfile.lock)", "find $home ! -user discourse -exec chown discourse {} \\+"]}
f284ba6caaf11348ebfe7cf15303e238b24049ee37f12ef3eda4cc38e7b8e351
==================== END REBUILD LOG ====================
Failed to rebuild app.
Checking your domain name . . .
Connection to community.museomix.org succeeded.
You should probably remove any non-standard plugins and rebuild.
Attempting to restart existing container. . .
starting up existing container
+ /usr/bin/docker start app
Error response from daemon: driver failed programming external connectivity on endpoint app (1eb09dca2e0d180222adb2130609d364a687eb4bac6a9ff929cd7469253e89f2): Error starting userland proxy: listen tcp4 0.0.0.0:443: listen: address already in use
Error: failed to start containers: app
Failed to restart the container.
==================== PLUGINS ====================
No non-official plugins detected.
See https://github.com/discourse/discourse/blob/main/lib/plugin/metadata.rb for the official list.
Discourse version at community.museomix.org: NOT FOUND
Discourse version at localhost: NOT FOUND
==================== MEMORY INFORMATION ====================
RAM (MB): 2099
total used free shared buff/cache available
Mem: 2001 155 476 0 1369 1680
Swap: 1023 53 970
==================== DISK SPACE CHECK ====================
---------- OS Disk Space ----------
Filesystem Size Used Avail Use% Mounted on
/dev/disk/by-label/DOROOT 50G 25G 23G 53% /
==================== DISK INFORMATION ====================
Disk /dev/vda: 50 GiB, 53687091200 bytes, 104857600 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 29B528BA-16C4-402E-BEE9-53555C8B6F10
Device Start End Sectors Size Type
/dev/vda1 2048 104855551 104853504 50G Linux filesystem
==================== END DISK INFORMATION ====================
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Or just send a test message to yourself.
Mail test skipped.
Replacing: SMTP_PASSWORD
Replacing: LETSENCRYPT_ACCOUNT_EMAIL
Replacing: DEVELOPER_EMAILS
Replacing: DISCOURSE_DB_PASSWORD
Replacing: Sending mail to
==================== DONE! ====================
You can examine the output of this script with
LESS=-Ri less /tmp/discourse-debug.txt
BUT FIRST, make sure that you know the first three commands below!!!
Commands to know when viewing the file with the above command (called 'less'):
q -- quit
/error<ENTER> -- search for the word 'error'
n -- search for the next occurrence
g -- go to the beginning of the file
f -- go forward a page
b -- go back a page
G -- go to the end of the file
