Metodo non definito `timeout=' per Regexp:Class
Ciao
Ho provato ad aggiornare tramite l’amministratore del sito online, ma non è riuscito e sto ricevendo questo errore:
/var/www/discourse/config/initializers/100-regex-timeout.rb:3:in `<main>': undefined method `timeout=' for Regexp:Class (NoMethodError)
Regexp.timeout = GlobalSetting.regex_timeout_seconds.to_i if GlobalSetting.regex_timeout_seconds.present?
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/engine.rb:667:in `load'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/engine.rb:667:in `block in load_config_initializer'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.4.3/lib/active_support/notifications.rb:208:in `instrument'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/engine.rb:666:in `load_config_initializer'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/engine.rb:620:in `block (2 levels) in <class:Engine>'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/engine.rb:619:in `each'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/engine.rb:619:in `block in <class:Engine>'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:32:in `instance_exec'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:32:in `run'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:61:in `block in run_initializers'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:228:in `block in tsort_each'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:422:in `block (2 levels) in each_strongly_connected_component_from'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:431:in `each_strongly_connected_component_from'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:421:in `block in each_strongly_connected_component_from'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:50:in `each'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:50:in `tsort_each_child'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:415:in `call'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:415:in `each_strongly_connected_component_from'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:349:in `block in each_strongly_connected_component'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:347:in `each'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:347:in `call'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:347:in `each_strongly_connected_component'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:226:in `tsort_each'
        from /usr/local/lib/ruby/3.1.0/tsort.rb:205:in `tsort_each'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:60:in `run_initializers'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/application.rb:372:in `initialize!'
        from /var/www/discourse/config/environment.rb:7:in `<top (required)>'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/pry-0.14.2/lib/pry/pry_class.rb:103:in `require'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/pry-0.14.2/lib/pry/pry_class.rb:103:in `block in load_requires'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/pry-0.14.2/lib/pry/pry_class.rb:102:in `each'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/pry-0.14.2/lib/pry/pry_class.rb:102:in `load_requires'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/pry-0.14.2/lib/pry/pry_class.rb:143:in `final_session_setup'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/pry-0.14.2/lib/pry/cli.rb:82:in `parse_options'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/pry-0.14.2/bin/pry:12:in `<top (required)>'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/bin/pry:25:in `load'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/bin/pry:25:in `<top (required)>'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli/exec.rb:58:in `load'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli/exec.rb:58:in `kernel_load'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli/exec.rb:23:in `run'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli.rb:491:in `exec'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli.rb:34:in `dispatch'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli.rb:28:in `start'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/exe/bundle:45:in `block in <top (required)>'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
        from /var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/exe/bundle:33:in `<top (required)>'
        from /usr/local/bin/bundle:25:in `load'
        from /usr/local/bin/bundle:25:in `<main>'
Mi sembra che tu stia eseguendo un’installazione non supportata, supportiamo solo Ruby 3.2 sulla base di codice Discourse più recente.
Dovremmo certamente migliorare la nostra comunicazione qui, l’app non dovrebbe darti errori criptici.
L’ho aggiornato manualmente dopo aver tenuto il forum offline per circa un’ora, questa pagina è stata molto utile
https://meta.discourse.org/t/manually-update-discourse-and-docker-image-to-latest/23325
Grazie per aver sollevato la questione @Samir_Sabri - sembra che non avessimo ancora aggiornato la versione minima richiesta in docker_manager (l’interfaccia utente che gli auto-ospitanti utilizzano per gli aggiornamenti). Una volta che questo sarà unito, le persone saranno invitate a eseguire una ricostruzione della CLI prima di aggiornare Discourse:
