Some users getting Unknown Error on login. Help!
absolute latest code (just updated).
NoMethodError (undefined method groups' for nil:NilClass) lib/plugin/instance.rb:284:in public_send’ lib/plugin/instance.rb:284:in block (2 levels) in add_to_class' (eval):94:in _fast_attributes’
confirmed: disabling the discourse-encrypt plugin makes it so those users can login again.
sam
(Sam Saffron)
3
I recall seeing something similar last week and I am pretty sure we fixed it.
Can you rebuild?
Yes. rebuilding and then re-enabling the plugin fixed the problem.
Thank you!
