Unsolving a topic does not remove the icon in the topic list
With the Discourse Solved plugin, if I uncheck the “Solved” checkbox in a topic, the tick icon is not removed from left of the topic title in the main topic list. This occurs when I uncheck the Solved checkbox, then click the forum logo to return to the main topic list. It does not occur if I reload the whole app using the browser’s reload button; the checkbox will no longer appear next to the topic title in that case (as expected).
Hmm maybe a solved plugin regression can you add this to your list @techapj.
Fixed via:
https://github.com/discourse/discourse-solved/commit/6177d2e1640dc49f4c0496e8bc1ade4c9c2a3c62
