Update Error: "CopyAddGroupsToAbout ComponentSettings" SQL
I am trying to update Discourse, using the web-updater and receive the following error, I also update frequently so it is not a long-due update:
Flushing service worker script
done
Running post deploy migrations
$ bundle exec rake multisite:migrate
1 migrations failed!
Failed to migrate default
#<StandardError:"An error has occurred, this and all later migrations canceled:\n\nPG::CardinalityViolation: ERROR:  more than one row returned by a subquery used as an expression\n">
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:56:in `block (2 levels) in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1004:in `block in with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:976:in `with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:55:in `block in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1119:in `log'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:54:in `raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:538:in `internal_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:137:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/query_cache.rb:27:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:48:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration/default_strategy.rb:10:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1059:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1025:in `block in say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/benchmark-0.4.0/lib/benchmark.rb:304:in `measure'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1025:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1048:in `method_missing'
/var/www/discourse/db/post_migrate/20250526063633_copy_add_groups_to_about_component_settings.rb:12:in `up'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:997:in `public_send'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:997:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:978:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:977:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:415:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:976:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1190:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1538:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:616:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:613:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:361:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1589:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1537:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1512:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1512:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1457:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1609:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1457:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1264:in `up'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/migration.rb:1239:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/tasks/database_tasks.rb:262:in `migrate'
/var/www/discourse/lib/tasks/db.rake:213:in `block (3 levels) in <main>'
/var/www/discourse/lib/tasks/db.rake:176:in `block (3 levels) in execute_concurrently'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `with_connection'
/var/www/discourse/lib/tasks/db.rake:174:in `block (2 levels) in execute_concurrently'
Multisite migrator is running using 1 threads
Migrating default
== 20250526063633 CopyAddGroupsToAboutComponentSettings: migrating ============
-- execute("SELECT name, value\nFROM theme_settings\nWHERE theme_id = (\n  SELECT id\n  FROM themes\n  WHERE name = 'Add Groups to About'\n  AND enabled = true\n)\n")
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:211:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:133:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:44:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:44:in `block in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/execution_wrapper.rb:91:in `wrap'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:70:in `conditional_executor'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:178:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.3.2/lib/thor.rb:538:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command/base.rb:73:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:71:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:149:in `with_argv'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/command.rb:69:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.2.2.1/lib/rails/commands.rb:18:in `<main>'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `require'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `block (2 levels) in replace_require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bootsnap-1.18.6/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
Looks like it could be an issue with this recent commit:
Let’s slip this over to Bug to see if it needs a closer look :eyes:
Thanks, I put a pri-high on this one, we will have a look over the next 5 business days.
Thank you for reporting this bug. The error occurs when the forum has a duplicated “Add Groups to About” component.
We made a fix to consider the most recently updated settings and ignore older ones. It will probably be merged tomorrow.
In the meantime, until the fix is merged, if you would like to safely update your forum to the latest version, you need to disable the other “Add Groups to About” components and leave only one enabled before updating.
EDIT: Fix was merged, please let me know when update still causes issue
This topic was automatically closed after 4 days. New replies are no longer allowed.
