Update fehlgeschlagen (postgresql)
Doing the newest update (incl. postgresql) result in an error:
root@community:/var/discourse# ./launcher rebuild app
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
cd /pups && git pull && /pups/bin/pups --stdin
Already up to date.
I, [2020-06-03T15:38:58.391364 #1] INFO -- : Loading --stdin
I, [2020-06-03T15:38:58.398128 #1] INFO -- : > locale-gen $LANG && update-locale
I, [2020-06-03T15:38:58.731357 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2020-06-03T15:38:58.731849 #1] INFO -- : > mkdir -p /shared/postgres_run
I, [2020-06-03T15:38:58.751775 #1] INFO -- :
I, [2020-06-03T15:38:58.756078 #1] INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2020-06-03T15:38:58.765806 #1] INFO -- :
I, [2020-06-03T15:38:58.766148 #1] INFO -- : > chmod 775 /shared/postgres_run
I, [2020-06-03T15:38:58.767966 #1] INFO -- :
I, [2020-06-03T15:38:58.768305 #1] INFO -- : > rm -fr /var/run/postgresql
I, [2020-06-03T15:38:58.770246 #1] INFO -- :
I, [2020-06-03T15:38:58.770626 #1] INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2020-06-03T15:38:58.785523 #1] INFO -- :
I, [2020-06-03T15:38:58.785863 #1] INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2020/06/03 15:38:58 socat[26] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2020-06-03T15:38:58.911895 #1] INFO -- :
I, [2020-06-03T15:38:58.912203 #1] INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2020-06-03T15:38:58.914376 #1] INFO -- :
I, [2020-06-03T15:38:58.914625 #1] INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2020-06-03T15:38:58.916280 #1] INFO -- :
I, [2020-06-03T15:38:58.916527 #1] INFO -- : > mkdir -p /shared/postgres_run/12-main.pg_stat_tmp
I, [2020-06-03T15:38:58.917967 #1] INFO -- :
I, [2020-06-03T15:38:58.918303 #1] INFO -- : > chown postgres:postgres /shared/postgres_run/12-main.pg_stat_tmp
I, [2020-06-03T15:38:58.919709 #1] INFO -- :
I, [2020-06-03T15:38:58.925728 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2020-06-03T15:38:58.928444 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2020-06-03T15:38:58.931357 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2020-06-03T15:38:58.934190 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2020-06-03T15:38:58.934528 #1] INFO -- : > chown -R root /var/lib/postgresql/12/main
I, [2020-06-03T15:40:44.749613 #1] INFO -- :
I, [2020-06-03T15:40:44.750250 #1] INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/12/bin/initdb -D /shared/postgres_data || exit 0
I, [2020-06-03T15:40:44.751653 #1] INFO -- :
I, [2020-06-03T15:40:44.751914 #1] INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2020-06-03T15:40:47.940064 #1] INFO -- :
I, [2020-06-03T15:40:47.940713 #1] INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2020-06-03T15:40:47.942521 #1] INFO -- :
I, [2020-06-03T15:40:47.942924 #1] INFO -- : > /root/upgrade_postgres
initdb: warning: enabling "trust" authentication for local connections
You can change this by editing pg_hba.conf or using the option -A, or
--auth-local and --auth-host, the next time you run initdb.
debconf: delaying package configuration, since apt-utils is not installed
I, [2020-06-03T15:42:45.495966 #1] INFO -- : Upgrading PostgreSQL from version 10 to 12
The files belonging to this database system will be owned by user "postgres".
This user must also own the server process.
The database cluster will be initialized with locale "en_US.UTF-8".
The default database encoding has accordingly been set to "UTF8".
The default text search configuration will be set to "english".
Data page checksums are disabled.
fixing permissions on existing directory /shared/postgres_data_new ... ok
creating subdirectories ... ok
selecting dynamic shared memory implementation ... posix
selecting default max_connections ... 100
selecting default shared_buffers ... 128MB
selecting default time zone ... Etc/UTC
creating configuration files ... ok
running bootstrap script ... ok
performing post-bootstrap initialization ... ok
syncing data to disk ... ok
Success. You can now start the database server using:
/usr/lib/postgresql/12/bin/pg_ctl -D /shared/postgres_data_new -l logfile start
Get:1 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Hit:2 http://deb.debian.org/debian buster InRelease
Get:3 http://deb.debian.org/debian buster-updates InRelease [49.3 kB]
Get:4 https://deb.nodesource.com/node_10.x buster InRelease [4,584 B]
Get:5 http://apt.postgresql.org/pub/repos/apt buster-pgdg InRelease [84.6 kB]
Get:6 http://security.debian.org/debian-security buster/updates/main amd64 Packages [201 kB]
Get:7 https://deb.nodesource.com/node_10.x buster/main amd64 Packages [768 B]
Get:8 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 Packages [171 kB]
Fetched 577 kB in 1s (698 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
postgresql-client-10
Suggested packages:
postgresql-doc-10
The following NEW packages will be installed:
postgresql-10 postgresql-client-10
0 upgraded, 2 newly installed, 0 to remove and 10 not upgraded.
Need to get 6,390 kB of archives.
After this operation, 30.6 MB of additional disk space will be used.
Get:1 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 postgresql-client-10 amd64 10.13-1.pgdg100+1 [1,428 kB]
Get:2 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 postgresql-10 amd64 10.13-1.pgdg100+1 [4,961 kB]
Fetched 6,390 kB in 0s (38.2 MB/s)
Selecting previously unselected package postgresql-client-10.
(Reading database ... 43929 files and directories currently installed.)
Preparing to unpack .../postgresql-client-10_10.13-1.pgdg100+1_amd64.deb ...
Unpacking postgresql-client-10 (10.13-1.pgdg100+1) ...
Selecting previously unselected package postgresql-10.
Preparing to unpack .../postgresql-10_10.13-1.pgdg100+1_amd64.deb ...
Unpacking postgresql-10 (10.13-1.pgdg100+1) ...
Setting up postgresql-client-10 (10.13-1.pgdg100+1) ...
update-alternatives: warning: forcing reinstallation of alternative /usr/share/postgresql/12/man/man1/psql.1.gz because link group psql.1.gz is broken
Setting up postgresql-10 (10.13-1.pgdg100+1) ...
Creating new PostgreSQL cluster 10/main ...
/usr/lib/postgresql/10/bin/initdb -D /var/lib/postgresql/10/main --auth-local peer --auth-host md5
The database cluster will be initialized with locale "C.UTF-8".
fixing permissions on existing directory /var/lib/postgresql/10/main ... ok
selecting default timezone ... Etc/UTC
pg_ctlcluster 10 main start
Warning: The selected stats_temp_directory /var/run/postgresql/10-main.pg_stat_tmp
is not writable for the cluster owner. Not adding this setting in
postgresql.conf.
Ver Cluster Port Status Owner Data directory Log file
10 main 5433 down postgres /var/lib/postgresql/10/main /var/log/postgresql/postgresql-10-main.log
update-alternatives: warning: forcing reinstallation of alternative /usr/share/postgresql/12/man/man1/postmaster.1.gz because link group postmaster.1.gz is broken
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of start.
Processing triggers for postgresql-common (213.pgdg100+1) ...
Building PostgreSQL dictionaries from installed myspell/hunspell packages...
Removing obsolete dictionary files:
Stopping PostgreSQL 10 database server: main.
Stopping PostgreSQL 12 database server: main.
Performing Consistency Checks
Checking cluster versions ok
The source cluster was not shut down cleanly.
Failure, exiting
UPGRADE OF POSTGRES FAILED
Please visit https://meta.discourse.org/t/postgresql-12-update/151236 for support
You can run ./launcher start app to restart your app in the meanwhile
FAILED
Pups::ExecError: /root/upgrade_postgres failed with return #<Process::Status: pid 45 exit 1>
exec failed with the params "/root/upgrade_postgres"
674042fc06e2af0c08a0a09c46406a0b18b1f08b9140e037fffe1053188bd1c0
Any idea why?
Hast du diesen Beitrag gelesen?
Ja, das habe ich schon einmal gemacht. Wir konnten das Update nicht zum Laufen bringen.
Lesen Sie den gesamten FAQ-Abschnitt hier:
Ich habe den Workaround bereits ausprobiert, aber er hat nicht funktioniert.
Das Protokoll ist voll von:
2020-06-03 16:01:21.074 UTC [693] FATAL: Das Datenverzeichnis “/shared/postgres_data” hat die falschen Berechtigungen.
2020-06-03 16:01:21.074 UTC [693] HINT: Der Server muss vom Benutzer gestartet werden, dem das Datenverzeichnis gehört.
Nach dem Einloggen in den Container habe ich versucht, ihn selbst herunterzufahren:
root@community-app:/etc/postgresql/10/main# service postgresql stop
[FAIL] Herunterfahren des PostgreSQL 10-Datenbank-Servers: main[…] Fehler: Der Besitzer der Konfiguration (postgres:106) und der Besitzer der Daten (Debian-exim:105) stimmen nicht überein, und der Besitzer der Konfiguration ist nicht root … fehlgeschlagen!
fehlgeschlagen!
Das Ausführen von chown -R postgres postgres_data im Verzeichnis /shared nach dem Betreten des Docker-Containers hat das Problem behoben.
