La mise à jour de PostgreSQL 13 depuis PostgreSQL 10 échoue
Suite à la discussion de Mise à jour vers PostgreSQL 13 :
Je suis sur une installation multisite avec une configuration à 2 conteneurs (seuls les modèles postgres.10 et redis sont actifs sur le conteneur de données). La version actuelle de PostgreSQL est la 10 et je souhaite passer à la 13. Voici l’erreur que je rencontre lors de la reconstruction du conteneur data :
fixing permissions on existing directory /shared/postgres_data_new ... ok
creating subdirectories ... ok
selecting dynamic shared memory implementation ... posix
selecting default max_connections ... 100
selecting default shared_buffers ... 128MB
selecting default time zone ... Etc/UTC
creating configuration files ... ok
running bootstrap script ... ok
performing post-bootstrap initialization ... ok
syncing data to disk ... ok
Success. You can now start the database server using:
    /usr/lib/postgresql/13/bin/pg_ctl -D /shared/postgres_data_new -l logfile start
Get:1 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Hit:2 http://deb.debian.org/debian buster InRelease
Get:3 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Get:4 http://apt.postgresql.org/pub/repos/apt buster-pgdg InRelease [104 kB]
Get:5 http://security.debian.org/debian-security buster/updates/main amd64 Packages [291 kB]
Get:6 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 Packages [231 kB]
Hit:7 https://deb.nodesource.com/node_15.x buster InRelease
Fetched 743 kB in 1s (944 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
  postgresql-client-10
Suggested packages:
  postgresql-doc-10
The following NEW packages will be installed:
  postgresql-10 postgresql-client-10
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 6,441 kB of archives.
After this operation, 30.6 MB of additional disk space will be used.
Get:1 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 postgresql-client-10 amd64 10.17-1.pgdg100+1 [1,439 kB]
Get:2 http://apt.postgresql.org/pub/repos/apt buster-pgdg/main amd64 postgresql-10 amd64 10.17-1.pgdg100+1 [5,002 kB]
Fetched 6,441 kB in 0s (34.9 MB/s)
Selecting previously unselected package postgresql-client-10.
(Reading database ... 43021 files and directories currently installed.)
Preparing to unpack .../postgresql-client-10_10.17-1.pgdg100+1_amd64.deb ...
Unpacking postgresql-client-10 (10.17-1.pgdg100+1) ...
Selecting previously unselected package postgresql-10.
Preparing to unpack .../postgresql-10_10.17-1.pgdg100+1_amd64.deb ...
Unpacking postgresql-10 (10.17-1.pgdg100+1) ...
Setting up postgresql-client-10 (10.17-1.pgdg100+1) ...
update-alternatives: warning: forcing reinstallation of alternative /usr/share/postgresql/13/man/man1/psql.1.gz because link group psql.1.gz is broken
Setting up postgresql-10 (10.17-1.pgdg100+1) ...
Creating new PostgreSQL cluster 10/main ...
/usr/lib/postgresql/10/bin/initdb -D /var/lib/postgresql/10/main --auth-local peer --auth-host md5
The files belonging to this database system will be owned by user "postgres".
This user must also own the server process.
The database cluster will be initialized with locale "C.UTF-8".
The default database encoding has accordingly been set to "UTF8".
The default text search configuration will be set to "english".
Data page checksums are disabled.
fixing permissions on existing directory /var/lib/postgresql/10/main ... ok
selecting default timezone ... Etc/UTC
    pg_ctlcluster 10 main start
Ver Cluster Port Status Owner    Data directory              Log file
10  main    5433 down   postgres /var/lib/postgresql/10/main /var/log/postgresql/postgresql-10-main.log
update-alternatives: warning: forcing reinstallation of alternative /usr/share/postgresql/13/man/man1/postmaster.1.gz because link group postmaster.1.gz is broken
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of start.
Processing triggers for postgresql-common (226.pgdg100+1) ...
Building PostgreSQL dictionaries from installed myspell/hunspell packages...
Removing obsolete dictionary files:
Stopping PostgreSQL 10 database server: main.
Stopping PostgreSQL 13 database server: main.
Performing Consistency Checks
Checking cluster versions                                   ok
The source cluster was not shut down cleanly.
Failure, exiting
UPGRADE OF POSTGRES FAILED
Please visit https://meta.discourse.org/t/postgresql-13-update/172563 for support.
You can run ./launcher start app to restart your app in the meanwhile
FAILED
Pups::ExecError: /root/upgrade_postgres failed with return #<Process::Status: pid 49 exit 1>
exec failed with the params "/root/upgrade_postgres"
1f253827e5700e1861c4e586213aaffa8994e452e43b9336301dcd02072e00f4
Si je réactive le modèle postgres.10, tout fonctionne à nouveau.
Savez-vous comment procéder pour effectuer la mise à niveau vers PostgreSQL 13 ?
PS : La mise à niveau vers PostgreSQL 12 échoue également.
J’ai vu qu’il faut arrêter le conteneur de données avant :
Voici ce que j’obtiens en exécutant tail -f shared/data/log/var-log/postgres/current après avoir arrêté les deux conteneurs :
2021-06-06 16:38:37.411 UTC [113] HINT:  Le serveur doit être démarré par l'utilisateur qui possède le répertoire de données.
2021-06-06 16:38:38.424 GMT [114] LOG:  fichier de configuration manquant ignoré "/shared/postgres_data/postgresql.auto.conf"
2021-06-06 16:38:38.424 UTC [114] FATAL:  le répertoire de données "/shared/postgres_data" a une propriété incorrecte
2021-06-06 16:38:38.424 UTC [114] HINT:  Le serveur doit être démarré par l'utilisateur qui possède le répertoire de données.
2021-06-06 16:38:39.439 GMT [115] LOG:  fichier de configuration manquant ignoré "/shared/postgres_data/postgresql.auto.conf"
2021-06-06 16:38:39.439 UTC [115] FATAL:  le répertoire de données "/shared/postgres_data" a une propriété incorrecte
2021-06-06 16:38:39.439 UTC [115] HINT:  Le serveur doit être démarré par l'utilisateur qui possède le répertoire de données.
2021-06-06 16:38:40.461 GMT [116] LOG:  fichier de configuration manquant ignoré "/shared/postgres_data/postgresql.auto.conf"
2021-06-06 16:38:40.461 UTC [116] FATAL:  le répertoire de données "/shared/postgres_data" a une propriété incorrecte
2021-06-06 16:38:40.461 UTC [116] HINT:  Le serveur doit être démarré par l'utilisateur qui possède le répertoire de données.
C’est probablement la source du problème. Comment puis-je le corriger ?
Par curiosité, qui est le propriétaire de votre répertoire postgres_data ?
Voici le résultat :
root@forum:/var/discourse/shared/data# ls -al
total 32
drwxr-xr-x  8 root root   4096 Jun  6 16:56 .
drwxr-xr-x  4 root root   4096 Mar  3  2019 ..
drwxr-xr-x  3 root root   4096 Jul  8  2018 log
drwxr-xr-x  2 _apt netdev 4096 Jul  7  2018 postgres_backup
drwx------ 20 _apt netdev 4096 Jun  6 17:29 postgres_data
drwx------ 19 _apt netdev 4096 Jun  6 16:56 postgres_data_new
drwxrwsr-x  5 _apt netdev 4096 Jun  6 17:29 postgres_run
drwxr-xr-x  2 lxd  lxd    4096 Jun  6 17:34 redis_data
Est-ce correct ?
Pour ma configuration (2 conteneurs, PostgreSQL 13), le groupe pour postgres_* est render et non netdev, et le bon groupe pour postgres_run est x, sans le bit setgid. Mais je ne sais pas vraiment ce que cela implique :sweat_smile:
PS : et redis_data est uuidd syslog …
Merci, je ne sais pas non plus :slight_smile:
J’espère que quelqu’un pourra aider !
Pourriez-vous exécuter la même commande avec ls -lan ? Cela aidera à déterminer les propriétaires (-n convertit le nom d’utilisateur en UID et le nom de groupe en GID). Voici un exemple de mon propre site avec une configuration à deux conteneurs :
[root@/var/discourse/shared/data]$ ls -lan
total 28
drwxr-xr-x.  7   0   0 4096 Jun  7 22:15 .
drwxr-xr-x.  5   0   0 4096 Jun  7 22:28 ..
drwxr-xr-x.  3   0   0 4096 Jun  7 22:15 log
drwxr-xr-x.  2 105 109 4096 Jun  7 22:15 postgres_backup
drwx------. 19 105 109 4096 Jun  7 22:27 postgres_data
drwxrwxr-x.  3 105 109 4096 Jun  7 22:27 postgres_run
drwxr-xr-x.  2 106 110 4096 Jun  8 00:17 redis_data
Bien sûr ! Voici :
root@forum:/var/discourse/shared/data# ls -lan
total 32
drwxr-xr-x  8   0   0 4096 Jun  6 16:56 .
drwxr-xr-x  4   0   0 4096 Mar  3  2019 ..
drwxr-xr-x  3   0   0 4096 Jul  8  2018 log
drwxr-xr-x  2 105 109 4096 Jul  7  2018 postgres_backup
drwx------ 20 105 109 4096 Jun  6 17:29 postgres_data
drwx------ 19 105 109 4096 Jun  6 16:56 postgres_data_new
drwxrwsr-x  5 105 109 4096 Jun  6 17:29 postgres_run
drwxr-xr-x  2 106 110 4096 Jun  9 14:10 redis_data
Bonjour,
Nous sommes dans la même situation, mais avec une configuration autonome. Le répertoire shared/standalone/log/var-log/ n’affiche aucun fichier, cependant, après avoir accédé au conteneur, nous observons les mêmes résultats :
root@pulp-discourse-iptools:/var/www/discourse# tail -n 3 /var/log/postgres/current
2021-10-13 18:33:04.027 GMT [917] LOG:  skipping missing configuration file "/shared/postgres_data/postgresql.auto.conf"
2021-10-13 18:33:04.028 UTC [917] FATAL:  data directory "/shared/postgres_data" has wrong ownership
2021-10-13 18:33:04.028 UTC [917] HINT:  The server must be started by the user that owns the data directory.
root@pulp-discourse-iptools:/var/www/discourse# ls -lan /shared
total 8
drwxr-xr-x 12    0   0  178 Oct 13 18:01 .
drwxr-xr-x 56    0   0  167 May 10  2020 ..
drwxr-xr-x  3 1000  33   21 Apr  3  2019 backups
drwxr-xr-x  4    0   0   34 Apr  3  2019 log
drwxr-xr-x  2  106 110    6 Apr  3  2019 postgres_backup
drwx------ 20  105 109 4096 Oct 13 17:57 postgres_data
drwx------ 19  105 109 4096 Oct 13 18:02 postgres_data_new
drwxrwsr-x  4  105 109   60 Oct 13 17:56 postgres_run
drwxr-xr-x  2  108 111   41 Oct 13 18:26 redis_data
drwxr-xr-x  4    0   0   44 Apr  3  2019 state
drwxr-xr-x  4 1000  33   37 Oct 13 18:26 tmp
drwxr-xr-x  4 1000  33   38 Apr  3  2019 uploads
Cependant, cela semble toujours étrange :
root@pulp-discourse-iptools:/var/www/discourse# ls -alF /shared | grep postgres_
drwxr-xr-x  2 postgres    postgres    6 Apr  3  2019 postgres_backup/
drwx------ 20 Debian-exim ssh      4096 Oct 13 18:53 postgres_data/
drwx------ 19 Debian-exim ssh      4096 Oct 13 18:02 postgres_data_new/
drwxrwsr-x  4 Debian-exim ssh        60 Oct 13 17:56 postgres_run/
Pour être plus prudent, nous sommes revenus à \"templates/postgres.10.template.yml\" dans app.yml et notre objectif actuel est simplement de redémarrer l’ancienne instance.
Il est peut-être pertinent de préciser que nous utilisons déjà le commit le plus récent de https://github.com/discourse/discourse_docker.git, après avoir basculé sur la branche main. Toutefois, comme la reconstruction n’a pas abouti, cela n’a probablement aucun impact lors du démarrage de l’image précédente, n’est-ce pas ?
Si quelqu’un a une idée pour résoudre cette situation, nous vous serions très reconnaissants. Sinon, nous reviendrons peut-être avec d’autres rapports.
Cordialement,
Andreas.
Salut à nouveau,
En suivant les conseils Update failed (postgresql) - #8 by noezDE de @noezDE (un grand merci), nous avons pu nous remettre de cette situation.
Maintenant, le site est de nouveau opérationnel et nous allons examiner une nouvelle mise à niveau.
Cordialement,
Andreas.
Procédure de récupération
Dans un premier temps, des progrès ont été réalisés en exécutant :
chown -R postgres /shared/postgres_data
sv restart postgres
Par la suite, les journaux ont indiqué :
2021-10-13 18:52:12.437 UTC [3357] FATAL: impossible de créer le fichier de verrouillage "/var/run/postgresql/.s.PGSQL.5432.lock" : Permission refusée
Nous avons donc opté pour une approche plus radicale en exécutant :
chown -R postgres:postgres /shared/postgres_*
sv restart postgres
Et voilà.
Nouvelle tentative avec \"templates/postgres.template.yml\" : tout s’est déroulé parfaitement et la mise à niveau de PostgreSQL 10 vers PostgreSQL 13 a réussi. Merci encore à toute l’équipe de Discourse pour leur excellent travail sur ce logiciel.
