Update unread counters after keyboard navigation
סיכום מבוסס בינה מלאכותית
A user, saj, reported an issue with unread counters not being updated after navigating back to the Latest index using keyboard navigation. However, codinghorror suggested that the issue might not be specific to keyboard navigation, but rather similar to using the browser’s back button. pfaffman asked if using “gl” to return to Latest would produce the same result. After further investigation, saj found that the issue is not reliably reproducible and unread counters are updated on some occasions, making it not a UX problem, but rather a technical issue that needs further investigation.
Let’s walk through a simple read workflow:
  1. Start at Latest.
  2. Using the mouse, navigate into a tracked topic. Read the topic.
  3. Using the mouse, navigate back to the Latest index by clicking on the logo at the top of the page.
When navigating with the mouse in this way, Discourse will automatically update the unread counters alongside the topic titles in the index.
Now repeat with keyboard navigation:
  1. Start at Latest.
  2. Using the keyboard (J, K, and RETURN), navigate into a tracked topic. Read the topic.
  3. Using the keyboard, strike the U key to return to the Latest index.
In this latter case, the unread counters are not automatically updated.
This feels like a case of cache incoherency. Is it fixable?
2 לייקים
Isn’t this the same as using the back button in the browser? Try it and see. I don’t think keyboard is the relevant bit here.
לייק 1
Do you get the same result if you return to latest with “gl”?
On second look, this does not appear to be reliably reproducible. Unread counters are updated and redrawn on some occasions. This is clearly not a UX problem. I’ll close out this topic and see if I can hone in on the conditions under which it does not work as expected. My apologies for the noise.
