アップグレード中止 - Unicornワーカーが不足しています
皆様、こんばんは。
お元気でお過ごしのことと存じます!!
セルフホスト型インスタンスでDiscourseのアップグレードを試みていますが、以下のエラーメッセージが表示されます。
*** 恐れ入りますが、次の手順にはしばらく時間がかかります ***
中止します。実行中のUnicornワーカーが不足しています
Docker Manager: アップグレードに失敗しました
#<RuntimeError: Not enough workers>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:41:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-8.0.4/lib/rails/commands/runner/runner_command.rb:44:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-8.0.4/lib/rails/commands/runner/runner_command.rb:44:in `block in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/execution_wrapper.rb:91:in `wrap'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-8.0.4/lib/rails/commands/runner/runner_command.rb:70:in `conditional_executor'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-8.0.4/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.4.0/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.4.0/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-8.0.4/lib/rails/command/base.rb:178:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/thor-1.4.0/lib/thor.rb:538:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-8.0.4/lib/rails/command/base.rb:73:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-8.0.4/lib/rails/command.rb:65:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-8.0.4/lib/rails/command.rb:143:in `with_argv'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-8.0.4/lib/rails/command.rb:63:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-8.0.4/lib/rails/commands.rb:18:in `<main>'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `require'
/usr/local/lib/ruby/3.3.0/bundled_gems.rb:69:in `block (2 levels) in replace_require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bootsnap-1.19.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
このエラーをトラブルシューティングして、インスタンスをアップグレードできるように手伝っていただけませんか?
現在、2025.12.0-latest を実行しています。
皆様のご協力とサポートに感謝いたします。
Cheers
BR
Terenui
コマンドラインから再構築を試しましたか?
いいえ、試していませんが、試すことはできます。具体的にどのコマンドラインを使えばよいでしょうか?理想的にはすべてをアップグレードするには?私はDiscourseを使い始めたばかりで、すべてのコマンド(例:rebuild、rakeなど)に戸惑うことがあります :smiley:
サーバーにsshした後、
通常は
cd /var/discourse
./launcher rebuild app
本当にありがとうございます、うまくいきました :wink:
