wglass
(Will Glass Husain)
September 23, 2015, 9:47pm
1
I’ve installed my copy of Discourse in a subfolder, per instructions here:
Discourse Official Statement about Subfolder setup
We support subfolder setups for our hosted customers at the enterprise level and up. Due to heavy technical setup complexity we strongly recommend you do not use this setup unless you are very experienced in custom subfolder setups.
It is critical you have a deep understanding of
NGINX setup in the Discourse Docker container
Secure original IP forwarding using custom headers in the proxy chain
Rate limiting in front proxy server
I…
I went to upgrade today to version 1.4. When I click “admin” / “upgrade”, I go to the wrong URL. When I manually go to /subfolder/admin/upgrade I see the menu but no list of upgrades. Looking under the hood there are two 404’s
GET /session/csrf
GET /admin/docker/repos
Suggestions?
riking
(Kane York)
September 23, 2015, 11:57pm
My question is: how has nobody noticed this before?
wglass
(Will Glass Husain)
September 24, 2015, 12:17am
3
One thing to note – I have two subfolders not one. If it’s helpful, here’s the run section of my app.yml.
run:
- exec:
cd: $home
cmd:
- mkdir -p public/ep/support
- cd public/ep/support && ln -s ../../uploads && ln -s ../../backups
- rm public/uploads
- rm public/backups
- replace:
global: true
filename: /etc/nginx/conf.d/discourse.conf
to: |
rewrite ^/(.*)$ /ep/support/$1 break;
proxy_pass http://discourse;
- replace:
to: |
etag off;
location /ep/support {
rewrite ^/ep/support/?(.*)$ /$1;
- replace:
to: $http_fastly_client_ip
global: true
It is possible we did not notice because our hosted customers don’t use this page.
We should look into this @neil in the meantime, use the SSH method to update your site. SSH in and do the three commands:
cd /var/discourse
git pull
./launcher rebuild app
wglass
(Will Glass Husain)
September 24, 2015, 5:36am
5
Thanks. The SSH method worked.
