Upgrade page links to https://admin/upgrade
Users are reporting a bug in Discourse version 1.4.3 and 1.4.4 where the upgrade link incorrectly points to https://admin/upgrade instead of the full domain (e.g., https://FQDN/admin/upgrade). This issue occurs even when running behind a reverse proxy and persists after updating the Docker manager. Blaisorblade notes that while the broken link is confusing, manually typing the correct URL allows the upgrade to proceed. fearlessfrog confirmed the same problem on v1.4.4, providing a screenshot of the broken link. sam stated they cannot reproduce the issue on the latest version and closed the thread, advising users to manually upgrade their instances using the command ./launcher rebuild app as the only resolution.
Short version: on Discourse 1.4.3, the upgrade link now leads literally to the broken https://admin/upgrade (and I don’t have admin as a hostname), both with the previous and the current docker_manager (if that makes a difference). This worked before, so it’s confusing. Thankfully, it’s a minor issue because I can’t still use the correct URL https://FQDN/admin/upgrade.
My Discourse is behind reverse proxy, but I don’t see config changes there that are obviously at fault.
Latest change I did was to the container .yml config, adding tiny as init process to workaround the bug in the AUFS kernel module.
What I did:
I’m running Discourse 1.4, and upgraded until 1.4.3. When trying to upgrade to 1.4.4, the upgrade link is to https://admin/upgrade instead of https://FQDN/admin/upgrade— not good.
But the latter page still “works” — upgrading Discourse is disabled, so I tried upgrading Docker manager hoping it’d help. This seems intended and normal, though the GUI does not show this dependency perfectly so I didn’t know this would help — indeed, people do get stuck. But this is a minor (and orthogonal) usability issue, so I’ll shut up
After that, the upgrade link still leads to https://admin/upgrade, but the correct URL works fine and allows me to complete the upgrade.
Same issue for v1.4.4 upgrade. Broken link as shown by this beautiful red arrow:
Manually typing the full address works ok.
I am not seeing this happen on latest so as much as this sucks I got to close this, only way to fix it is upgrade your instance and we can not do that without you doing a manual upgrade
cd /var/discourse
