I’m trying to upload a 14.4MB backup to my VPS and get this message after 20%
//cdck-file-uploads-global.s3.dualstack.us-west-2.amazonaws.com/meta/original/3X/6/9/690beb2215180e83a5effd4b472f6095c20d65f9.jpg
this is the output of df though:
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/ploop21283p1 11220208 2410508 8285604 23% /
none 4 0 4 0% /sys/fs/cgroup
none 104860 72 104788 1% /run
none 524288 0 524288 0% /dev/shm
none 5120 0 5120 0% /run/lock
none 524288 0 524288 0% /run/shm
none 102400 0 102400 0% /run/user
What could be the cause of this error?
I wonder if there is something wrong with your VPS since this is the second time you have reported unexplainable out of disk errors.
michaeld
(Michael - Communiteq)
25. Mai 2015 um 20:56
3
Try making a backup first on that VPS, then upload the existing one.
def has_enough_space_on_disk?(size)
`df -Pk #{Rails.root}/public/backups | awk 'NR==2 {print $4 * 1024;}'`.to_i > size
This function fails when the public/backups directory does not exist (making a backup creates it).
Maybe add another check?
Hmm, @techapj can you repro that, is this a bug when the folder does not exist?
sam
(Sam Saffron)
25. Mai 2015 um 21:27
5
If using Discourse Docker the folder will be there.
Based on previous discussions I thought @hedgehog is using our official Docker install for his Discourse.. perhaps he can clarify on this point?
After creating a backup and then uploading the one I want to use I get the message that it uploaded successfully but it never appears in the backup-list. Any ideas?
@codinghorror
After trying the whole weekend I wasn’t able to get Discourse running on the pesky OVH-host so I tried pl3bs’ installation-script. I know I could pay more and get better Discourse-hosting but I’m dead set on the cheap solution just for the sake of beeing able to say “yes, it does work”.
michaeld
26. Mai 2015 um 10:45
8
Maybe go there for support? Since this clutters meta with all kinds of weird stuff that never happens to other people.
