تحميل favicon.ico
Attempting to upload an icon.ico hangs the setup page button to “uploading…” without any indication that it isn’t supported.
Replicate with https://thebobsgamingnetwork.net/favicon.ico and a fresh install of discourse.
إعجاب واحد (1)
Yeah, the problem is that ico is not among the extensions authorized at the first start (it can be added later). We should add the authorized extensions to the wizard
4 إعجابات
ICO is an obsolete format for the web – I strongly recommend using simple PNG or JPG instead.
4 إعجابات
I think it’s better to show a proper error message since ICO are deprecated…
5 إعجابات
Can we give this to @techAPJ? All we need to do is show an educational panel if someone tries to upload an obsolete ICO file.
إعجابَين (2)
We will now show proper error message (received from server side) when upload fails in wizard and re-enable the upload button. This issue was applicable on “Logos” step too.
Demo:
I also updated the help text on “Icons” step to indicate recommended image extensions.
5 إعجابات
