`uploads:migrate_to_s3` fails with 'Seahorse::Client::NetworkingError: certificate verify failed' on Digital Ocean Spaces
סיכום מבוסס בינה מלאכותית
md-misko encountered an SSL certificate error (Seahorse::Client::NetworkingError: certificate verify failed) while attempting to migrate uploads to DigitalOcean Spaces using rake uploads:migrate_to_s3. The issue appeared to stem from missing root certificates, as referenced in an AWS SDK Ruby issue. Although md-misko tried setting Aws.config[:ssl_ca_bundle] to a local CA bundle, the setting didn’t persist across rake tasks. Ultimately, md-misko discovered the real issue: the DISCOURSE_S3_ENDPOINT environment variable was incorrectly formatted — it included the bucket name (e.g., https://mybucket.sfo2.digitaloceanspaces.com), when it should have only contained the region endpoint (e.g., https://sfo2.digitaloceanspaces.com). After correcting the endpoint, the migration succeeded. The issue was configuration-related, not certificate-related, and the topic was resolved and closed.
I need help with moving the existing uploads to Digital Ocean Spaces (S3 is properly configured and new uploads are successfully uploaded).
I ran rake uploads:migrate_to_s3 with:
DISCOURSE_S3_ACCESS_KEY_ID="id" \
DISCOURSE_S3_SECRET_ACCESS_KEY="secret" \
DISCOURSE_S3_REGION="sfo2" \
DISCOURSE_S3_BUCKET="mybucket/uploads" \
DISCOURSE_S3_ENDPOINT="https://mybucket.sfo2.digitaloceanspaces.com" \
DRY_RUN=1 rake uploads:migrate_to_s3 --trace
but the rake is aborted with:
Seahorse::Client::NetworkingError: SSL_connect returned=1 errno=0 state=error: certificate verify failed (unspecified certificate verification error)
which indicates possible missing root certificate for DO spaces, as reported here:
https://github.com/amazon-archives/aws-sdk-core-ruby/issues/166
Short answer is the Ruby SDK no longer bundles a SSL certificate. It relies on OpenSSL in Ruby being correctly configured. The linked issue above gives some simple work-arounds for when this is not the case.
One of the workarounds there mentions setting the
Aws.config[:ssl_ca_bundle] = '/path/to/ca-bundle.crt'
I downloaded the file to ‘/shared/ca-bundle.crt’ and set it in rails console, but I can’t seem to make this persistent (rake task fails again, and after checking the setting in rails console, it is reverted back to nil).
Full trace:
** Invoke uploads:migrate_to_s3 (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute uploads:migrate_to_s3
Checking if default already migrated...
13252 of 13261 uploads are not migrated to S3. S3 migration failed for db 'default'.
10052 posts are not remapped to new S3 upload URL. S3 migration failed for db 'default'.
** Invoke posts:missing_uploads (first_time)
** Execute posts:missing_uploads
Looking for missing uploads on: default
0 post uploads are missing.
No posts require rebaking
****************************** DRY RUN ******************************
Migrating uploads to S3 for 'default'...
Uploading files to S3...
 - Listing local files
.............. => 14025 files
 - Listing S3 files
rake aborted!
/usr/local/lib/ruby/2.6.0/net/protocol.rb:44:in `connect_nonblock'
/usr/local/lib/ruby/2.6.0/net/protocol.rb:44:in `ssl_socket_connect'
/usr/local/lib/ruby/2.6.0/net/http.rb:996:in `connect'
/usr/local/lib/ruby/2.6.0/net/http.rb:930:in `do_start'
/usr/local/lib/ruby/2.6.0/net/http.rb:925:in `start'
/usr/local/lib/ruby/2.6.0/delegate.rb:83:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/seahorse/client/net_http/connection_pool.rb:299:in `start_session'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/seahorse/client/net_http/connection_pool.rb:97:in `session_for'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/seahorse/client/net_http/handler.rb:121:in `session'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/seahorse/client/net_http/handler.rb:73:in `transmit'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/seahorse/client/net_http/handler.rb:47:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/seahorse/client/plugins/content_length.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/s3_signer.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/s3_signer.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/s3_host_id.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/xml/error_handler.rb:8:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/transfer_encoding.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/helpful_socket_errors.rb:10:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/s3_signer.rb:89:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/redirects.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/retry_errors.rb:177:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/retry_errors.rb:208:in `retry_request'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/retry_errors.rb:191:in `retry_if_possible'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/retry_errors.rb:179:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/dualstack.rb:34:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/accelerate.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/md5s.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/bucket_name_restrictions.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/expect_100_continue.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/bucket_dns.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/bucket_arn.rb:47:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/rest/handler.rb:8:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/user_agent.rb:11:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/seahorse/client/plugins/endpoint.rb:45:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/param_validator.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/seahorse/client/plugins/raise_response_errors.rb:14:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/sse_cpk.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/dualstack.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/plugins/accelerate.rb:35:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/jsonvalue_converter.rb:20:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/idempotency_token.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/param_converter.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/aws-sdk-core/plugins/response_paging.rb:10:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/seahorse/client/plugins/response_target.rb:23:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-core-3.89.1/lib/seahorse/client/request.rb:70:in `send_request'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/aws-sdk-s3-1.60.1/lib/aws-sdk-s3/client.rb:6637:in `list_objects_v2'
/var/www/discourse/lib/file_store/to_s3_migration.rb:178:in `block in migrate_to_s3'
/var/www/discourse/lib/file_store/to_s3_migration.rb:177:in `loop'
/var/www/discourse/lib/file_store/to_s3_migration.rb:177:in `migrate_to_s3'
/var/www/discourse/lib/file_store/to_s3_migration.rb:61:in `migrate'
/var/www/discourse/lib/tasks/uploads.rake:239:in `migrate_to_s3'
/var/www/discourse/lib/tasks/uploads.rake:218:in `block in migrate_to_s3_all_sites'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.0.7/lib/rails_multisite/connection_management.rb:63:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.0.7/lib/rails_multisite/connection_management.rb:73:in `each_connection'
/var/www/discourse/lib/tasks/uploads.rake:216:in `migrate_to_s3_all_sites'
/var/www/discourse/lib/tasks/uploads.rake:212:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:160:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:125:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:110:in `top_level'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:186:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:80:in `run'
bin/rake:13:in `<top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli/exec.rb:63:in `load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli/exec.rb:63:in `kernel_load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli/exec.rb:28:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli.rb:476:in `exec'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor.rb:399:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli.rb:30:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/vendor/thor/lib/thor/base.rb:476:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/cli.rb:24:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/exe/bundle:46:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/lib/bundler/friendly_errors.rb:123:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.1/exe/bundle:34:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => uploads:migrate_to_s3
I found the error, the s3_endpoint parameter with rake was wrong :blush: , it should only include location, without the bucket name prefixed (the same as defined in admin—site settings—s3 endpoint):
DISCOURSE_S3_ENDPOINT="https://sfo2.digitaloceanspaces.com"
This topic can be closed.
