Usage rights of CoC
סיכום מבוסס בינה מלאכותית
The discussion revolves around the usage rights of the Discourse Code of Conduct (CoC). AlexandraB inquires about how communities can leverage and use the Discourse CoC, and sam clarifies that the CoC is adapted from the Contributor Covenant version 1.4, released under the Creative Commons Attribution 4.0 International Public License.
sam explains that the only modification made to the original CoC was replacing [INSERT EMAIL ADDRESS] with team@discourse.org. AlexandraB asks for clarification on the required attribution, and sam provides the difference between the original and the Discourse CoC.
AlexandraB proposes an attribution statement, which sam suggests is not necessary, recommending to use the original Contributor Covenant attribution instead. AlexandraB expresses willingness to give Discourse credit for introducing her to the Contributor Covenant.
The conversation concludes with AlexandraB thanking the team for their help and codinghorror commenting on the necessity of seeking clarification on Twitter.
How are community managers and communities allowed to leverage and use the Discourse CoC for their communities? Is this under a creative commons or something?
What are the usage rights?
Discussion here as well: Update code-of-conduct.md by aabowen · Pull Request #4892 · discourse/discourse · GitHub
Our CoC: discourse/docs/code-of-conduct.md at 5dbd6a304bed5400be481d71061d3e3ebb4d6785 · discourse/discourse · GitHub
Is adapted from the version 1.4, CoC
The text is pretty much exactly the same as https://www.contributor-covenant.org/it/version/1/4/code-of-conduct/ except that we added our email.
The Contributor Covenant is released under the Creative Commons Attribution 4.0 International Public License, which requires that attribution be included. (which we do)
So what do you mean by “attribution”? Can you be specific on what needs to be included?
Thanks.
Does this suffice?
“This Code of Conduct is adapted from the Discourse Code of Conduct available at discourse/docs/code-of-conduct.md at 5dbd6a304bed5400be481d71061d3e3ebb4d6785 · discourse/discourse · GitHub. and based on The Contributor Covenant version 1.4. It is released under the Creative Commons Attribution 4.0 International Public License”
Wait, if you have issues with the copy of http://contributor-covenant.org/ why not raise it with them? I don’t want to diverge our copy from the original.
Ah you’re suggesting I just use theirs which is:
This Code of Conduct is adapted from the [Contributor Covenant][homepage], version 1.4,
available at [https://www.contributor-covenant.org/it/version/1/4/code-of-conduct/][version]
I guess I don’t know how much you added/changed from their original. So, since you edited/added to their CoC, and I’m wanting to edit/add to yours - I thought perhaps I’d need to attribute you, not Contributor Covenant?
I asked on twitter:
https://twitter.com/CoralineAda/status/869625618614374402
https://twitter.com/CoralineAda/status/869625766887247872
This is the only difference we have between the original and ours:
sam@ubuntu docs % diff code_of_conduct.md code-of-conduct.md
58c58
< reported by contacting the project team at [INSERT EMAIL ADDRESS]. All
> reported by contacting the project team at team@discourse.org. All
We replaced [INSERT EMAIL ADDRESS] with team@discourse.org, I do not see why I need to include an extra clause in our code of conduct cause we made that change to license that.
Ok, great! Thanks for you help. I didn’t realize that was all you updated. Just wanted to confirm and make sure I’m giving credit where credit is due. I think I will still give Discourse a nod, because I found the Contributor Covenant from you!
Thanks team. :slight_smile:
I don’t know that we needed to bug someone on Twitter over a single email address? But I guess that is clear now…
Yeah, as mentioned I didn’t realize all you changed was the email address. I like to be 100% clear and certain with things like this, and wanted to make sure Discourse didn’t need attribution…
Appreciate the help and apologies for any inconvenience!
