User cannot delete own topics once they have replies
Hi,
I might be missing something obvious but I cannot see it.
The items to appear in the post menu are as follows:
Admin can see as above but users see less options:
Any ideas?
Thanks.
You can delete posts, but not topics. (I can’t quite tell from your picture if you’re trying to delete a topic).
Thanks, that’s why then! It was a topic.
Although maybe it would be a good thing if users could delete a topic as long as it didn’t have any replies.
Cheers!
I agree. I’ve just run into this with a regular member who is leading a group in our forum. I set up a category for them to play with, but they cannot delete their topics—even those without any replies.
The current workaround here is to ask them to flag, in practice posting a topic and then changing mind about it is quite rare.
If we wanted to be ultra fancy here I guess we could allow end users to tombstone and close the topic if it has no replies (waiting 24 hours till actual deletion). In practice we find it ultra rare for users to change mind about posting a topic. If they do they usually follow up with, can you please close this it is a duplicate of: <link to topic> (either in a flag or followup reply)
Yes, why don’t we do that? And only for, say, the first day after creating it if there’s some kind of “topic creator’s remorse” or … something.
That sounds reasonable and just fancy enough. Sometimes if a topic doesn’t get any replies, it is good to have a way to kill it off. We’ve also had cases where a new category is seeded with topics before being opened up to other members, and some of those topics need to be deleted before the category going live.
@zogstrip can you spec and assign this? It should behave very similarly to post deletion with additional limits (no replies, only created in the last 24 hours, etc).
@nbianca, can you take this?
We need to allow any users to delete their own topic provided it was created in the past 24 hours and there hasn’t been any replies yet.
Deleting your own topic will make a new revision and put a stub in place (only for non-staff members) like we do for any other posts except the text will be different. Something like
(topic withdrawn by author, will be deleted in 24 hours unless flagged)
The stub will be destroyed after 24 hours by the DestroyOldDeletionStubs job.
I think that stub is visible to all users. It is a public notice of intent to withdraw.
Within 24 hours of posting the topic and zero replies seems safe. Note that replies after the intent to withdraw is in place may be implicitly deleted as well but nobody can say they were not warned…
I meant we only put the stub when a non-staff user delete their own topic. This logic should not apply to staff.
This is done in:
https://github.com/discourse/discourse/pull/7267
This doesn’t seem to work. We just had our first user create and delete their own topic. Another user came along and posted a reply before the 24-hour period was up. The time period has now expired and the topic was not removed.
Yes, that’s possible, the topic can’t be removed if there are replies to it – then one user would indirectly be deleting another user’s posts.
The idea is that stating public intent to delete in the first and only post of the topic should be enough notice that people shouldn’t reply to the topic. Odd that someone ignored that road sign :stop_sign:
You wrote above that “replies after the intent to withdraw is in place will be implicitly deleted as well”. Now you’re saying the topic can’t be removed if there are replies to it. Which is it supposed to be? Make up your mind, please. Or perhaps the topic should close when withdrawn to prevent any replies.
I guess I did say that… I’m still hesitant to have one user delete another user’s posts, even if accidentally. What do you think @eviltrout?
In the meantime, I’m giving some delete functions a little exercise myself :sweat_smile:
Could we perhaps disable replies until the 24 hour period is up?
Easiest way to do that is to make a topic self delete also close the topic at the time the intent to delete is stated? @nbianca can you take that?
Can users undelete and re-open the topic if they change their mind?
One question and one issue to report:
Q: Does replying to a deleted topic in the form of a new personal message also invoke the topic-replied workflow? I ask because one user created and then deleted a topic within minutes early yesterday, there are no replies on it but I did send a reply as a personal message yesterday. It’s been over 36 hours, but the topic has not been auto-deleted (there are no flags either).
Bug/issue: This topic seems to be included in the summary emails as I can confirm from the “Preview Summary” (with an empty body but showing the title and info about the user who posted it). This is certainly undesired, deleted topics should be filtered out.
