Gebruiker ziet geen afbeeldingen
A forum user is experiencing issues viewing images due to a problem with their Norton VPN. Octoberon reports that the issue resolves when the VPN is turned off, but is seeking a more permanent solution. pfaffman suggests that Norton may be blocking the site, possibly due to a misconfigured Cloudflare or Cloudfront IP. pfaffman also provides a potential solution from Norton’s support pages, and Octoberon has asked the user to try changing their VPN region to see if it resolves the issue.
One of the members of my forum is reporting that he can’t see images in posts.
I don’t think it’s a problem at my end as no one else is experiencing the same issue as far as I know, Also, he says the issue clears if he switches off his Norton VPN.
Has anyone see this sort of thing before with a VPN? I use (a differnent) one all the time without any problems.
I recently moved the storage to S3 with a Cloudfront CDN but that was a few weeks go. I don’t believe the issue is related to that, unless I’m missing something.
So, have him switch off his Norton VPN or ask them why they broke your site?
A guess is that someone else uses cloudflare and Norton thinks they are bad, so they block everyone who uses cloudfront (or that cloudfront IP).
Switching off the VPN is a workaround but not a solution.
The VPN shouldn’t be blocking anything. Isn’t it the endpoint that would be blocking the VPN IP? A search didn’t turn up much. I’ll have to dig around AWS.
I think that it’s Norton’s fault. This is what I found in 7 seconds. It might not be the solution.
I’ve asked him to try changing the VPN region. We’ll see what difference if makes.
