Benutzervertrauensstufen – wirkt die Änderung rückwirkend?
Hi, if I change the Trust Levels of Level 0 to lower standards, I expected several users to get bumped up instantly to Level 1. But they did not. I even did some checking of a user, and his stats for reading time and number of posts read etc was now above the new threshold but the user remained at Level 0.
Do these changes not work retroactively, or do they simply take a little time?
Thanks!
I think that stuff runs once a day. You can look in /sidekiq if you’re self-hosted.
That and new sign-ups don’t show up right away. As @pfaffman said, the routine runs once a day. Once it has run, things should show up. (We went through this with some newbies not showing up in the user directory.)
